Serpentine Belt replacement - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 6 (permalink) Old 12-23-2013, 05:23 AM Thread Starter
Points: 6,746, Level: 1 Points: 6,746, Level: 1 Points: 6,746, Level: 1
trucrz's Avatar
Car: 2008 Chrysler 300C CRD LE
Has anyone done the front drive belt on a CRD, if so,what is the best way to get to it?
Sent from AutoGuide.com App
G Grip Grill, Koni Street Shocks, Lowered King Springs, Fog light LED Halos, 20" SRT Replica Wheels. Chrome Window Pillar trim, No Limit Tuning chip, Tinted Windows.
"No one can ruin your day without your permission"
trucrz is offline
post #2 of 6 (permalink) Old 02-27-2014, 04:33 PM
Points: 2,718, Level: 1 Points: 2,718, Level: 1 Points: 2,718, Level: 1
Chris77's Avatar
Hi There
In basic form off the top of my head
Take engine cover off
Take turbo intake pipe off (black plastic)
Take metal turbo pipe off (alloy intake)
Take off black box (resonator) that metal turbo intake pipe joins.
The belt tensioner is behind the resonator. Once the resonator is removed, use a socket on the tensioner to gain slack. There should be a pin hole to lock off the tensioner to facilitate a belt change. The new belt is still tight to get on. You should change the two plastic pulleys at the same time. They start to rattle which becomes prominent in the car. Refit in reverse. Careful of sharp edges on the back of the radiator. Good finger grazers!
Chris77 is offline
The Following User Says Thank You to Chris77 For This Useful Post:
trucrz (02-27-2014)
post #3 of 6 (permalink) Old 02-27-2014, 05:00 PM Thread Starter
trucrz's Avatar
Thanks Chris, its great help. I will have a go at it soon I have a belt kit that includes the pulleys
trucrz is offline
post #4 of 6 (permalink) Old 02-27-2014, 05:19 PM
Chris77's Avatar
I can't remember but you may also need to remove the air box just for elbow room. Its only one bolt and lift off. You may be OK. Just a point to note, there is a torx screw and a circlip on the end of the alloy pipe which secures it to the resonator. Both remove easily just don't loose them as they keep the pressurised air in. There is also a rubber "o" ring on each end of the metal pipe which seals in the pressurised air. Careful not to pinch this on refit. Its a straightforward job. Have fun!
Chris77 is offline
trucrz (02-27-2014)
post #5 of 6 (permalink) Old 03-02-2014, 04:30 PM
Chris77's Avatar
You might also need this
Chris77 is offline
post #6 of 6 (permalink) Old 03-02-2014, 08:21 PM Thread Starter
trucrz's Avatar
Thanks Chris you have been very helpful
trucrz is offline
how do you change a Serpentine Belt anthonycam79 General Discussion on Issues / Trouble Shooting 20 11-19-2016 03:36 PM
Markings on Serpentine Belt Tensioner TheFifthWave General Discussion on Issues / Trouble Shooting 8 08-18-2013 07:38 AM
waterpump, serpentine belt Tomi33 General Discussion 7 03-05-2013 07:19 AM
serpentine belt tensioner Pappajohn UK & Europe Regional Forum 3 11-02-2012 08:54 AM
Is the Hemi Cam Driven by the Serpentine Belt? artichoke Power Train 19 04-26-2006 03:13 AM
