Code C1042 - Right Front Tone Wheel? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 80 (permalink) Old 02-14-2013, 02:53 AM Thread Starter
Points: 8,998, Level: 1 Points: 8,998, Level: 1 Points: 8,998, Level: 1
Car: 2007 Chrysler 300c Touring CRD
Keep getting this error on my 300c.
The ABS fault lights up inside, generally whilst taking a corner. It started in the cold so I thought it may be to do with either the traction or a sensor freezing up. Whilst it appears less sensitive in the warm, it does not seem to be going away and is happening more frequently.
Any ideas on what needs fixing?
Chrysler 300C Touring Lux, Black, CRD, Startech Grill, Sat Nav, Boston Premium Sound System, Parrot and a boss tow bar
Needs the following: Working lights, Speakers to Stop Rattling, Spare Key
sibeer is offline
post #2 of 80 (permalink) Old 02-14-2013, 03:26 AM
Elite Contributing Member
There is a sensor at the rear of each wheel that detects the rotational speed by counting the pulses as teeth pass the sensor.
Could be Bad Connection, Dirty Sensor, damaged or missing teeth/tooth or more serious problem.
Find the sensor and check it looks OK and face doesnt have debris on it. Check teeth for damage or missing teeth. Check for continuity of detector with an ohmeter (About 1000 to 5000 Ohms at a guess).
Code is basically saying this particular wheel speed is intermittently dropping for some reason and soes not match the other wheels.
If it definitley only happens when cornering it is prbably the wheel bearing that has excessive play and when you corner the gap between the face of the sensor and the wheel gets too big and the signal would be lost. So if its definitley linked to cornering I would first just check the wheel bearing for excessive play.
Jack
jackwalton is offline
The Following 2 Users Say Thank You to jackwalton For This Useful Post:
moe300 (02-14-2013), sibeer (02-21-2013)
post #3 of 80 (permalink) Old 02-14-2013, 04:15 AM
Points: 8,961, Level: 1 Points: 8,961, Level: 1 Points: 8,961, Level: 1
dm575's Avatar
Car: 2007 Chrysler 300C Touring CRD
Not sure about the sensors on the 300C but on a lot of cars they are magnetic and so pick up all sorts of metallic cr*p which can reduce their performance. A reseat of the connectors where the fly leads connect to the body has fixed problems for me in the past. Squirt of WD40 and a number of replugs to clean up the contacts. Worth a go.
dm575 is offline
The Following User Says Thank You to dm575 For This Useful Post:
sibeer (02-21-2013)
post #4 of 80 (permalink) Old 02-14-2013, 07:19 AM Thread Starter
Thanks guys, good little project for the weekend for me.
sibeer is offline
post #5 of 80 (permalink) Old 02-14-2013, 01:56 PM
Points: 15,468, Level: 1 Points: 15,468, Level: 1 Points: 15,468, Level: 1
steadyaway's Avatar
Car: 2007 Chrysler 300c CRD (XBV)
Re: Code C1042 - Right Front Tone Wheel?
Also, check the state of the reluctor ring (located on the back of the hub) to make sure a loose disc shield hasn't worn it. And while you are there make sure the disc shield is secure and not obstructing the sensor. It may be neither of these but as they only cost time they are worth a look.
Forgive the typo's, I'm on my phone!
Alternator shroud
Rosen A7 roof mounted DVD
Veba DTV tuner
Parrot CK3000 Bluetooth Hands free
Startech Illuminated Side Skirts, Grille and boot spoiler
Boot liner
steadyaway is offline
The Following User Says Thank You to steadyaway For This Useful Post:
sibeer (02-21-2013)
post #6 of 80 (permalink) Old 02-21-2013, 08:07 AM Thread Starter
OK, had it off and would note the following:
All was fairly clean and a little extra cleaning has made no difference.
No teeth in site.
Reluctor ring seems to be in good condition. Very slightly rough in a couple of areas, but same on the other side.
Plugs and connections all looked good, WD40'd anyway.
Didn't have my multimeter so will dig that out to check the continuity of the sensor tomorrow and compare to the one opposite.
Any other ideas?
sibeer is offline
post #7 of 80 (permalink) Old 02-21-2013, 10:26 AM
Points: 146,940, Level: 1 Points: 146,940, Level: 1 Points: 146,940, Level: 1
badgx's Avatar
Clear the code and go drive a few miles & check if the cruise control works OK. If light comes back, you may need to replace the abs sensor, fairly common problem which triggers the abs light & shuts down the cruise control, esp etc
badgx is offline
post #8 of 80 (permalink) Old 02-21-2013, 11:34 AM
No teeth in site.
Any other ideas?
Did you mean no Teeth missing ?
Alternative would be bad connection or faulty detector. Its just a simple coil so should have a fixed resistance/inductance, but may be an intermittent fault.
It may finally be necessary to check resistance from ECM or just buy and fit a new sensor.
Jack
post #9 of 80 (permalink) Old 02-21-2013, 02:24 PM
Points: 9,563, Level: 1 Points: 9,563, Level: 1 Points: 9,563, Level: 1
Petman's Avatar
Car: 2006 Chrysler 300c CRD
If you need a new sensor, try here (parts are in stock and they are VERY quick)
Parts for your Chrysler 300C
Petman is offline
The Following User Says Thank You to Petman For This Useful Post:
Sonsarus Amaryllus (02-22-2013)
post #10 of 80 (permalink) Old 02-22-2013, 02:16 AM
Major Contributing Member
Points: 35,818, Level: 1 Points: 35,818, Level: 1 Points: 35,818, Level: 1
keat's Avatar
Car: 2008 Chrysler Now in a Kia Sportage
The ABS ring on my kids swift was cracked, it wasn't loose or freely rotating, but the ABS sensor knew something wasn't right.
I guess you'd have spotted this though.
keat is offline
C121a code, steering wheel angle sensor issue. xxsjxx1 Problems / Dealer Service 1 01-26-2010 03:27 PM
Custom Paint- candy? two tone? two tone w/ candy? Race-Tek Motorsports Appearance General Discussion 15 07-04-2007 09:29 AM
Front Wheel problems?? jgcruz Custom Wheels & Tires 0 02-09-2006 05:35 PM
Front wheel geometry frank29 General Discussion 10 05-14-2005 08:34 PM
Replace with
