Hi,
I might buy 300c crd touring, but it depends on few things. First I need to know if there's possible to have a real LSD instead of braking spinning wheels. Does Hemi LSD's work with CRD rearend? I assume that the gearing is different. Is there othe differencies and can V8 models rearend be attached to CRD? What about other Mopar SRT rearends? What's the ratio in those? It would be the easiest way to get some SRT rearend up there, if ratios aren't a problem.
Thank you!
Other "buts" I'll think about later if this rearend question turns out to be manageable with reasonable price.
Thank you!
