Sounds like you have water leaking into the headlight assembly, most likely at the reflector-to-lens joint.
You can drive the moisture out by removing the bulb and applying heat to the outside of the lens with a hair dryer.
Ultimately you will have to reseal the reflector-to-lens joint.
