how to bleed coolant system - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 13 (permalink) Old 12-03-2012, 02:16 PM Thread Starter
Points: 103,480, Level: 1 Points: 103,480, Level: 1 Points: 103,480, Level: 1
Car: 2005 chrysler 300C
after you changed the radiator?
help please.
what is the process, pour coolant in the system and then what?
jwhezzy2003 is offline
post #2 of 13 (permalink) Old 12-03-2012, 02:20 PM
Points: 37,638, Level: 1 Points: 37,638, Level: 1 Points: 37,638, Level: 1
If its a V8 it should bleed with a few short runs and topping up the coolant. There is a bleed screw on the water pump, but mine stripped and I couldn't slacken it. That's what I did recently and had no problems.
ivanford is offline
post #3 of 13 (permalink) Old 12-03-2012, 02:27 PM Thread Starter
I did that and cracked the other radiator
Should I cut the car off after it reaches a certain temp (what temp???) and then cut it back on because when I was doing it that way the coolant didn't get sucked into the engine, so while waiting the temperature reached 230 and the other radiator blew @ that temperature. $150 down the drain.
post #4 of 13 (permalink) Old 12-03-2012, 02:32 PM
With the car idling in the garage I topped up the coolant as full as I could, then after a few minutes running I shut it off and let it go cold, then did this a few times more before driving the car. Then for a few days I topped up after every journey, when the engine was cold.
ivanford is offline
post #5 of 13 (permalink) Old 12-03-2012, 02:42 PM Thread Starter
ok thanks. Now I have to order another radiator and hope for the best. Im use to driving a honda that had a bleed screw on the thermostat housing
post #6 of 13 (permalink) Old 12-03-2012, 02:56 PM
In can't see how air in the system would burst the radiator, are you sure you didn't get a faulty replacement.
ivanford is offline
post #7 of 13 (permalink) Old 12-03-2012, 02:57 PM Thread Starter
thats what im thinking but yeah the radiator started draining coolant in the middle of the radiator so I think it cracked. Im going to go to autozone and try to get my money back, they might tell me to talk to the manufacture or something. IDK.
post #8 of 13 (permalink) Old 12-03-2012, 03:06 PM Thread Starter
just talked to autozone they said they will order me a replacement....yeesssss
post #9 of 13 (permalink) Old 12-03-2012, 06:46 PM
Major Contributing Member
Points: 3,673, Level: 1 Points: 3,673, Level: 1 Points: 3,673, Level: 1
MikeHTally's Avatar
Park it nose up with the cap off, heater on full hot. Let it idle 'til it's fully warmed up. Keep adding the coolant mix 'til the reservoir is at the mark.
MikeHTally is offline
post #10 of 13 (permalink) Old 06-19-2015, 08:53 PM
Points: 8,894, Level: 1 Points: 8,894, Level: 1 Points: 8,894, Level: 1
Car: 2007 Chrysler 300C SRT-8
so once this is done, how much coolent and distilled water do you add? I seen two jugs of coolent and two gallons of distilled water in another post.
loveblazen is offline
Is it necessary to bleed brakes when replacing pads? agape300 Brakes 16 06-27-2013 09:35 AM
Advice required, 5.7 coolant system bleed bolt stripped ? ivanford UK & Europe Regional Forum 9 10-19-2012 04:02 AM
Coolant system, hole in radiator, bad fan motor. The 4 Js General Discussion on Issues / Trouble Shooting 0 03-19-2012 02:56 PM
(Moved) Audio system questions and observations (2011 system) Natisfaction Car Audio/Alarms/UConnect/Navigation 0 12-18-2011 06:34 AM
Coolant system Bobquinn 1st Gen SRT8-Specific General Discussion 2 03-13-2008 01:43 PM
