URGENT! Cooling fan not coming on! - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 20 (permalink) Old 06-22-2008, 01:00 PM Thread Starter
Points: 1,664, Level: 1 Points: 1,664, Level: 1 Points: 1,664, Level: 1
Car: 2006 Chrysler 300C SRT-8
Send a message via AIM to Bdot Send a message via MSN to Bdot Send a message via Yahoo to Bdot
Exclamation URGENT! Cooling fan not coming on!
I am at a local M&G, on the way my cooling fans stopped running. Even when the A/C is turned on I have no fans running. Fuse is good, no trouble codes, what could cause this?
'06 300C SRT-8 with 31k on the clock.
'06 300C SRT-8
  • aFe Stage II
  • Predator [Perf CAI 93]
  • 180 Thermostat
Bdot is offline
post #2 of 20 (permalink) Old 06-24-2008, 05:09 PM
Points: 6,046, Level: 1 Points: 6,046, Level: 1 Points: 6,046, Level: 1
Cibalo's Avatar
what is your temperature reading on the car? Does it get hot when sitting still? If it is you need to run your heater to pull the engine temp down. Get it to the dealer and have them look at it. If it gets too hot you could warp a head.
GRIP IT AND RIP IT!
Cibalo is offline
post #3 of 20 (permalink) Old 06-24-2008, 05:49 PM
Points: 69,597, Level: 1 Points: 69,597, Level: 1 Points: 69,597, Level: 1
Check that the relays in the front power distribution center are fully inserted in their sockets. One or two of them control the fans. Pull one out at a time and re-insert it. Then another.
DESIREE is offline
post #4 of 20 (permalink) Old 06-25-2008, 04:29 AM
JMA
Points: 920, Level: 1 Points: 920, Level: 1 Points: 920, Level: 1
Car: 2004 Chryler Intrepid
Fan motor is bad
in my case one only stop working
one little electric motor $ 260.00 + labor 1 hr to change
had this problem on two different chrysler Intrepid
JMA is offline
post #5 of 20 (permalink) Old 06-25-2008, 09:01 AM
Major Contributing Member
Points: 29,993, Level: 1 Points: 29,993, Level: 1 Points: 29,993, Level: 1
fuse any good?
bund is offline
post #6 of 20 (permalink) Old 06-28-2008, 03:50 PM Thread Starter
Fuses and relays were fine. Took it to the dealer Monday and it turns out the motor in both fans were done. Has since been fixed and I added a few mods to the car as well.
Bdot is offline
post #7 of 20 (permalink) Old 06-28-2008, 05:13 PM
Elite Contributing Member
Running the fans with Predator has been known to burn out the fans.
joey is offline
post #8 of 20 (permalink) Old 06-28-2008, 06:58 PM
That i did not know, glad to learn that before i consider buying a predator
bund is offline
post #9 of 20 (permalink) Old 06-28-2008, 07:45 PM
With the Predator you can control what temp the fans come on. You can leave it stock if you want. So no need to worry about buying the Predator. A lot of folks set the fans to come on earlier than stock, which I think is around 219 degrees, to keep the engine temps lower.
joey is offline
post #10 of 20 (permalink) Old 08-17-2008, 10:31 PM
Points: 461, Level: 1 Points: 461, Level: 1 Points: 461, Level: 1
qdtaylor's Avatar
Car: 2006 Dodge Magnum SRT8
Exclamation FANS NOT WORKING...what the TRUCK is going on
I dont have a 300 but my 06 Magnum SRT 8 with 41K on the clock, engine cooling fans just stopped running convienetly at my local STEALership. I am told $590 and i will be back on the road with two fan motors, i cant afford it. I want to do this on my own. I already got taken for a ride with $480 "brake pads ONLY" for the front and $410 for the rear which i am told by Hunter Dodge in Lancaster, CA that these are priced becuase it is a perfpormance vehicle and everyone pays these prices, I am not everyone. Does anyknow any place to buy these fan motors and are the simple enough to replace for a shade tree mechanic, or do i stock up on Ramen noodle now and give in to the dealership ? I NEED HELP NOW someone email me and let me know?
I dont have any mods just plain ol stock SRT8 Magnum
qdtaylor is offline
Looking for metal radiator cooling fan blades GoldNnasty Engine Cooling 3 08-09-2009 06:04 AM
Cooling Fan Making Noise???? 300cboy Engine Cooling 10 03-15-2008 06:43 PM
How-To: COOLING FAN crunching noise source found/FIX!!! GoofyTimL Tech Tips - DIY - How-To 11 07-10-2007 08:04 AM
COOLING FAN sounds like it is crunching rocks!!! HELP. SRTHILL Engine Cooling 50 07-08-2007 08:50 AM
Cooling Fan seems to be running too much... formerBMW540 Engine Cooling 0 05-02-2007 08:46 AM
