Cooling Problem - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 12 (permalink) Old 10-01-2008, 09:10 AM Thread Starter
Points: 662, Level: 1 Points: 662, Level: 1 Points: 662, Level: 1
Cooling Problem
Well I have had the 300c for a little over a month now and just yesterday the check engine light came on. Took it over to the local AutoZone to read the code. Of course I ahve already forgotten the code number but the code point at a bad thermostat or coolant sensor. Of course it has to be multiple guess and can't marrow it it down to one. Any idea which is more likely? I am defineltly goning to replace both and go with a 180 deg thermostat but can't get anything done till sunday. Is this to long to wait? I will anly put about 10 miles on my car a day till then. Thanks for your time and your help?
Kombat_Khuck is offline
post #2 of 12 (permalink) Old 10-01-2008, 09:51 AM
Points: 86,810, Level: 1 Points: 86,810, Level: 1 Points: 86,810, Level: 1
Activity: 29% Activity: 29% Activity: 29%
GoofyTimL's Avatar
Car: '15 300C Platinum Jazz Blue; '07 MSRT8 Bright Silver MSRT: Edelbrock SC w/ InTune, 402flaps, Stealth HIDs, misc BT stuff, dual pin stripes, 35% tint 300C Pt: 35% tint, SpLx Pedal Set so far
What was your temperature guage reading? What was the digital readout in the EVIC diagnostic menu (hold music and menu buttons simultaneously for about 7-10 sec to see the diagnostic menu then up or down through the pages).
Why would you go to Autozone vs. the local Chrysler/Dodge dealer for the read or the fix?
If you've lost the ability to monitor your temperature, but you're confident the thermostat is functioning properly, then I'd say you're okay until the weekend. If not... then get it to the dealer. Got any warranty coverage from your purhcase date, or an extended contract?
but now there's the 300C Platinum and an Edelbrock SC Magnum SRT8!
GoofyTimL is offline
post #3 of 12 (permalink) Old 10-01-2008, 10:26 AM Thread Starter
Ok I did not know about the holding the two buttons down to get to another menu. I will try that after I get out of work. To the best of my knowledge I think it is the sensor but I am saying this only from observing the engine when the light first came on and I don't believe that the engine is overheating. I have checked the dipstick about a hundred times checking to see if there is any coolant in the engine but have yet to find any, which leads me to believe that the thermostat is not totally messed up and since it doesn't look like it is overheating maybe I will cross my fingers and baby it for a couple of days. I only went to Autozone because they will check the code fast and free. I am hoping to wait to the weekend because I want to do it myself and that is the when my schedule frees up and I was planning of upgrading the thermostat to the 180 deg here in a free months when I put on a free other mods so why do the thermostat twice?
post #4 of 12 (permalink) Old 10-01-2008, 09:41 PM
Elite Contributing Member
Last winter I got a TSTAT code, I think PO128 -THERMOSTAT RATIONALITY a couple of different times.
The second time I checked my Evic temps and they were in the mid 170's, when they should have been in the 195 - 203 range.
My TSTAT must have been stuck open, or opening early, for a few days.
Then everything went back to normal and the DTC's stopped appearing.
joey is offline
post #5 of 12 (permalink) Old 10-01-2008, 09:53 PM
GoofyTimL's Avatar
Sounds like you're not too knowledgeable about cars (not trying to knock you). So let me be clear...
You don't check the coolant level with a dipstick. The dipstick is for the oil level... it's over by the fuse box... and it says oil on the pull tab. I sure hope you can see a level on that dipstick. If not, you need oil and soon... you're more than a quart low... maybe two quarts!
The coolant level you can see in your overflow reservoir... that tank behind the air filter box on the driver's side. The level should be somewhere between Min and Max., particularly when cold.
The transmission fluid level has no dipstick and only your dealer can tell you about that. But if the car is shifting okay then transmission fluid is not your problem.
post #6 of 12 (permalink) Old 10-01-2008, 10:08 PM
Points: 26,977, Level: 1 Points: 26,977, Level: 1 Points: 26,977, Level: 1
one you didnt mention was did you hear your fans kick on? reason i say is if your tsat was messed your fans would kick on but if they didnt i think you may have a small sensor fault drive it nice and easy and if you see the temp gauge go past half way then start to watch it, if it keeps climbing you got a problem houston let us know how it goes bud
CoolVSRT8 is offline
post #7 of 12 (permalink) Old 10-02-2008, 11:36 PM
Points: 4,058, Level: 1 Points: 4,058, Level: 1 Points: 4,058, Level: 1
SyNz's Avatar
Car: 2007 Chrysler 300 awd
Send a message via MSN to SyNz
theromstat problems
Last week my 300 overheated first it stopped blowing warm and then finally overheated...took a week to order a thermostat from Toronto... finally got it installed and found out that its a engine oil cooler problem and need to order it back east again...another 5 days *sighs* and what I was told that there is a problem with many others and other makes causing thermostats to go...that is what i understood when the service department explained it to me...so im hopeing to get my car back next wednesday!!
SyNz is offline
post #8 of 12 (permalink) Old 10-03-2008, 12:24 AM
there she is! get it back soon! and pm me when your online next time got a meet coming up
post #9 of 12 (permalink) Old 10-03-2008, 03:53 PM
SyNz's Avatar
hey sure sounds like fun...if i ever get my baby back lol let me know when and where the meet is looking forward to it!!
SyNz is offline
post #10 of 12 (permalink) Old 10-03-2008, 04:24 PM
lets us know when you get it back and we meet every tuesday send me a pm ill give you the 411 on it
Cooling issue hemifever Engine Cooling 2 07-26-2009 04:08 PM
Cooling Fans/ High temp problem khaleal Engine Cooling 6 03-24-2009 05:41 PM
Frankencooler is Here. Modular Auxiliary Cooling For The 5.7/6.1 MattRobertson Engine Cooling 27 09-27-2008 01:06 PM
A/C not cooling shyane Problems / Dealer Service 1 03-13-2008 01:57 PM
Cooling Fan seems to be running too much... formerBMW540 Engine Cooling 0 05-02-2007 09:46 AM
