Please help. P0471 Exhaust Pressure Sensor - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 08-30-2012, 03:54 AM   #21 (permalink)
Points: 25,284, Level: 1 Points: 25,284, Level: 1 Points: 25,284, Level: 1
Activity: 32% Activity: 32% Activity: 32%
Member Number: 37145
Originally Posted by UK CHRYSLER 300C View Post
DPF's have 2 steel pipes entering and leaving them,cats don't so it should be easy to spot which one is which....easy really
Cheers, I was right in the first place then (thought I was going mad). The second box has a pressure pipe just before and after it.
Regards
Simon
www.custom300cshop.co.uk
Old 08-30-2012, 07:32 AM   #22 (permalink)
Points: 5,333, Level: 1 Points: 5,333, Level: 1 Points: 5,333, Level: 1
Member Number: 28359
Yes Simon you were right all along. I caused the confusion by quoting from Chrysler spares manual which shows the DPF in the wrong place. But as you say, the DPF has a pipe before and after to measure the differential pressure and to automatically start regen process or warn if its getting blocked.
If the Diff pressure sensors are working properly, error codes should be flagged up before a blocked DPF starts effecting performance though.
Jack
jackwalton is online now
Old 08-30-2012, 08:23 AM   #23 (permalink)
Points: 770, Level: 1 Points: 770, Level: 1 Points: 770, Level: 1
Car: 2008 Chrysler 300C CRD
Member Number: 26700
Originally Posted by jackwalton View Post
This is happening more and more.
Think its the brain working faster than the fingers.
A good job it does Jack otherwise we'd all be in trouble!
Morgan is offline
Old 08-30-2012, 09:38 AM   #24 (permalink)
Yes good point otherwise typing would be like this eh ! a;elkrgnkan oisgd;lkqje vczxajrlfjqle
Old 08-30-2012, 12:57 PM   #25 (permalink)
Points: 35,987, Level: 1 Points: 35,987, Level: 1 Points: 35,987, Level: 1
Activity: 57% Activity: 57% Activity: 57%
UK CHRYSLER 300C's Avatar
Member Number: 12398
Stop swearing Jack, I know that language.....
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
Old 09-03-2012, 05:21 AM   #26 (permalink)
Points: 606, Level: 1 Points: 606, Level: 1 Points: 606, Level: 1
Car: 2006 Chrysler 300C 3.0 CDR
Member Number: 39561
removed DPF for inspection, but everything is fine - nothing unusual, DPF isn't foul.
Today going to check hoses once again. Car is still twitching on every faster acceleration...
vyckal is offline
Old 09-03-2012, 07:51 AM   #27 (permalink)
First I would check for any further error codes, particularly different ones, and clear existing codes.
It is also possible that the pressure sensor itself is faulty and needs changing but I dont think that would cause the driving symptoms you've got, but you never know.
If you have a multimeter you could check the pressure sensors resistance and output voltage rather than just fit a replacement.
Also possible EGR solenoid fault which is easily bypassed with a 4.7K resistor and takes just a few minutes to fit. When my EGR failed it definitley caused twitching at about 1500RPM but also eventually brought up a different error code to yours. Initially I had the twitching and like a "chirp" noise but no fault codes at all.
Alternativley you could clean the Mass Air Flow detector (MAF), but you need to clean it with the correct solution.
Aletrnative is a blockage in other parts of the exhaust system.
The above are only my opinions I am no expert, you may get better advice from much wiser and more experienced people than me. I am sure you will get many differing opinions though.
Good luck and keep us informed.
Cheapest and quickest starting point would be to fit a 4.7K resistor in place of EGR valve and see what happens to driving/twitching.
JUST SEARCHED OTHER POSTS AND "james1978" POSTED SIMILAR PROBLEMS AND IT WAS ACTUALLY A FAULTY EXHAUST PRESSURE SENSOR, SO IT APPEARS THAT A FAULTY SENSOR CAN CAUSE THE SYPTOMS YOU DESCRIBE. DONT KNOW HOW TO POST THE LINK BUT IF YOU SEARCH FOR "james1978" POSTS OR P0471 YOU WILL GET TO IT.
Jack
Last edited by jackwalton; 09-03-2012 at 08:35 AM. Reason: Added Cheapest and quickest bit.
The Following User Says Thank You to jackwalton For This Useful Post:
Donatello75 (11-19-2012)
Old 09-04-2012, 09:15 AM   #28 (permalink)
I think the relevent pressure sensor is underneath the plastic engine cover and screws into the top of the EGR valve body at the rear LH side of the engine (LH when your sat in the drivers seat), near the engine bulhead (or "firewall" as the yanks say).
I would be tempted to remove the sensor and make sure the hole to the pressure sensor is not blocked up with crud. If it is you could carefully poke or drill it out.
Jack
The Following 2 Users Say Thank You to jackwalton For This Useful Post:
Donatello75 (11-19-2012), vyckal (09-16-2012)
Old 09-04-2012, 03:23 PM   #29 (permalink)
Major Contributing Member
Points: 14,657, Level: 1 Points: 14,657, Level: 1 Points: 14,657, Level: 1
Armchair's Avatar
Car: 2009 Chrysler 300c crd SRT Design
Member Number: 28455
I have a theory that wicam's dpf got clogged up because he drove his car in limp mode for a while IIRC. I believe the normal regeneration cycle is suspended when the car is in limp mode.
Armchair is offline
Old 09-16-2012, 11:50 AM   #30 (permalink)
Finally fixed my car!
The problem was with SENSOR, Pressure, Exhaust back pressure (the photo below) part number 05175812AA
Bought used sensor fro 25 pounds and car drives like new!
Thanks for everybody who tried to help me! Appreciate for this!
Uploaded with ImageShack.us
vyckal is offline
The Following 2 Users Say Thank You to vyckal For This Useful Post:
Donatello75 (11-19-2012), suzieque (01-26-2013)
Tyre pressure sensor Classicgold European & Diesel Powered 300 Models 67 12-21-2011 01:38 PM
where is the exhaust pressure sensor located? james1978 European & Diesel Powered 300 Models 1 06-08-2011 03:13 PM
Malfunction - Oil pressure sensor Macca Australia Forum 11 03-13-2011 06:12 PM
Oil Pressure Sensor nxtcsrt8 SRT8-Specific General Discussion 0 09-23-2009 06:53 PM
Pressure Sensor PappaD General Discussion 2 05-06-2007 08:22 AM
