Intermittent Battery Light - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 10-21-2012, 09:42 AM   #21 (permalink)
Major Contributing Member
Points: 7,787, Level: 1 Points: 7,787, Level: 1 Points: 7,787, Level: 1
devilmaycare's Avatar
Member Number: 7282
Originally Posted by pesty View Post
At idle I am getting 15V/14.5V ish occasionally dropping to 12.0 V thats when the bong happens and battery light comes on dash. A quick rev makes it go away again
Looks like your alternator output is intermittant. Have you also checked your accessory drive belt for slipping? Is your power steering OK on full lock and is your A/C working OK? The pipe on your last photo doesn't look right; there is clip missing and the joint is separating.
If you are able to retrieve fault codes, you may find: P065A - Powertrain - Generator Performance.
Last edited by devilmaycare; 10-21-2012 at 10:09 AM. Reason: Fault code info added.
devilmaycare is online now
Old 10-21-2012, 11:08 AM   #22 (permalink)
Points: 25,257, Level: 1 Points: 25,257, Level: 1 Points: 25,257, Level: 1
Member Number: 37145
The pipes that are leaking is the two fuel pipes that the jubilee clips are known to come loose and leak fuel on to the rear of the alternator, they should have been checked during the service. I cannot see the shield fitted to the alternator either. Get it to the dealer and kick arse!
Regards
Simon
www.custom300cshop.co.uk
Simon@thecustom300cshop is online now
Old 10-21-2012, 11:15 AM   #23 (permalink)
Points: 55,028, Level: 1 Points: 55,028, Level: 1 Points: 55,028, Level: 1
Activity: 28% Activity: 28% Activity: 28%
Car: Chrysler 300c 2009 CRD
Member Number: 37144
the last picture has been leaking, and i would renew the clip and push the hose on to the ridge and secure proper, then order a pair of hoses to change them
IIRC one is this-
http://www.ebay.co.uk/itm/Blue-Silic...item27bbd68678
the other -
http://www.ebay.co.uk/itm/Blue-Silic...item3f0b04e96e
The Following User Says Thank You to paul@thecustom300cshop For This Useful Post:
devilmaycare (10-22-2012)
Old 10-22-2012, 12:09 PM   #24 (permalink)
Member Number: 7282
Tracing the messy pipes up I found this
I've just checked my pipes and they look very much the same. The clip is there, but hard to see because of the grime and the screw is hidden behind the pipe. So must order some new silicone hoses, as recommended by Paul.
Old 10-22-2012, 12:21 PM   #25 (permalink)
one of the pipe are 9mm and one 8mm IIRC, one is a right pig to do the other easy, as i had to warm the 8mm to expand it a bit over the 9mm, as i 10mm hose wont fit.
Old 10-22-2012, 01:00 PM   #26 (permalink)
Member Number: 7282
I see that hoses come in 8mm and 9.5mm; can you remember which pipe is which? I wonder why they used two slightly different pipe sizes? Also, what size clips are recommended?
Old 10-22-2012, 01:12 PM   #27 (permalink)
i think i have the offcut's so ill check tomorrow and let you know
Old 11-26-2012, 12:07 PM   #28 (permalink)
Points: 2,181, Level: 1 Points: 2,181, Level: 1 Points: 2,181, Level: 1
Car: 09 chrysler 300c
Member Number: 38161
Hi Guys,
An update on this sorry its taken so long. Due to my car being my office and lots of working away I have had to use My mothers car and my weekend car (ironically 20 years old and on original alternator.) my mothers car is an 03 with 125k on the clock and has not let her down since new.....anyway
Sooo after getting several quotes all around £600 mark and finding out the RAC would not pick me up again for the same fault meaning driving more than 25 miles very risky I decided to try the Doncaster chrysler dealer which opened very recently.
After some tooing and frowing they got word from Chrysler that for good will they would Pay towards labour I would just pay for the part. Meaning total £601 bill.
As this made it the same as other places I went for it.
1) I got a genuine new part fitted and 2 years warrenty on it
2)I got my old alternator back which I intend to get repaired, other places wanted to keep the old one as they were fitting refurbed ones anyway and they got money back when sending it in, yet still were charging £400 for the part. I could get it from euro car parts for £190 with discount and sending the old one back.
So I picked my car up today after 18hrs labour. Yes you read that right 18 hours!!!! for an alternator. Apparently they hadn't done one before and had some problems.. you don't say!
Anyway glad to get my beast back. It really is a huge ball ache not having my car available.
pesty is offline
Old 11-26-2012, 01:06 PM   #29 (permalink)
Points: 2,833, Level: 1 Points: 2,833, Level: 1 Points: 2,833, Level: 1
Member Number: 41160
Hi Guys,
Should have got UK Chrysler 300c to do the job.
he can do one in 1hr 20mins apparently.
Mercedes quote 1hr 40mins for the job.
took me around 10hrs (2 evenings in my garage)
never done one before but had a couple of hurdles to overcome...one being the cast stud on the tensioner to relieve the belt tension had broken off....the other being inadequate tools ie: no torx spanners, only sockets
Pappajohn is offline
Old 11-26-2012, 02:19 PM   #30 (permalink)
Points: 35,919, Level: 1 Points: 35,919, Level: 1 Points: 35,919, Level: 1
Activity: 54% Activity: 54% Activity: 54%
UK CHRYSLER 300C's Avatar
Member Number: 12398
It's a piece of cake to change....I can't see what all the fuss is about....we had a look at Dee's CRuD a couple of weeks ago for a MOT and change both top wishbones and while it was there we had a look to compare it with the MB alternator we changed a few weeks earlier and there's more room in the C and the only difference was the Aircon pipe attached on the C and from underneath we could see that it moves out of the way plenty enough to get the alt out from the top.....easy peasy
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
Battery Light Question DWEW European & Diesel Powered 300 Models 31 08-02-2012 03:50 PM
Intermittent HVAC Position Selector Light (tap it enough and it works) CDN300T General Discussion on Issues / Trouble Shooting 4 09-30-2011 04:34 PM
Battery light, followed by transmission limp home, followed by engine light buddygunz European & Diesel Powered 300 Models 2 04-16-2011 11:35 AM
Intermittent Airbag light dave699 European & Diesel Powered 300 Models 7 09-19-2010 08:09 PM
Battery Light!!!! Ukyo Yoshiro Problems / Dealer Service 6 09-04-2006 01:21 PM
