Intermittent Battery Light - Page 7 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 11-27-2012, 01:52 PM   #61 (permalink)
Major Contributing Member
Points: 7,775, Level: 1 Points: 7,775, Level: 1 Points: 7,775, Level: 1
devilmaycare's Avatar
Member Number: 7282
Can anyone explain why official Chrysler service data appears to be at total variance with customer experiences; at least for alternator replacement? I will admit, though, that 0.5 hrs labour does seem a bit optimistic. The lengthiest item in the list is 1.8 hrs for water pump replacement, followed by starter motor at 1.3 hrs.
devilmaycare is offline
Old 11-28-2012, 11:58 AM   #62 (permalink)
Points: 1,894, Level: 1 Points: 1,894, Level: 1 Points: 1,894, Level: 1
matrix1975's Avatar
Car: 2008 Chrysler 300C CRD [YNK]
Member Number: 27470
I'm sure I was told Chrysler take the alternator out from underneath the car somehow. So maybe it is that quick if it comes out that way?? But even then it does still seem very optimistic.
Took me just under 3 hours to pull my alternator out today with coffee and phone calls interspersed. Then again - I'm not a mechanic - I'm a programmer.
Mine had a battery light a couple of times back in September. My battery is sound apparently. I've had no battery lights since but the voltages in EVIC are very erratic. It sat at 12.6v for ages on Sunday and then shot up and held at 15.2v. So, car was parked on drive and alternator pulled out this morning.
matrix1975 is offline
Old 11-28-2012, 12:17 PM   #63 (permalink)
Points: 25,223, Level: 1 Points: 25,223, Level: 1 Points: 25,223, Level: 1
Member Number: 37145
If yours hasn't died completely you may get away with replacing the brush/regulator pack on the rear of it, just make sure you remove the old unit and inspect the copper armature and make sure it is intact on the end of the shaft. Any signs of flaking copper and its screwed.
Regards
Simon
www.custom300cshop.co.uk
Simon@thecustom300cshop is online now
Old 11-28-2012, 12:54 PM   #64 (permalink)
Member Number: 7282
At least you should be able to sort out your PC in much less time, after it crashes!
I wonder if MB, in their quest for hi-tech solutions, have ever considered brushless alternators? They do exist; used to be called magnetos years ago.
Old 11-28-2012, 01:15 PM   #65 (permalink)
matrix1975's Avatar
Yes, that's what was wrong with my first alternator which was replaced 18 months ago. The slip ring had a very tiny bit of copper missing. This alternator has always had a shield and I've regularly checked the fuel lines are not leaking at all, plus taken great care when changing the oil etc.
I want to pull this one apart without destroying the voltage regulator if its possible!
Old 11-28-2012, 01:42 PM   #66 (permalink)
Was the alternator that was fitted 18mth ago done by a Chrysler dealer? If it was a genuine part it would still be under warranty.
Old 11-28-2012, 01:54 PM   #67 (permalink)
matrix1975's Avatar
No, it was bought from a third party and was fitted by myself and Steve Gee. As far as I'm aware it was brand new and not a reconditioned unit. I assume it only had a 12 month warranty though.
Old 11-28-2012, 02:11 PM   #68 (permalink)
Member Number: 7282
How thick is the copper surface? I hope its more substantial than a thin plating. If it is the latter case, its no wonder they fail so easily.
Old 11-28-2012, 02:20 PM   #69 (permalink)
matrix1975's Avatar
No, unfortunately the copper plating is very very thin. So I don't imagine it does take much to start stripping it away.
Old 11-28-2012, 03:04 PM   #70 (permalink)
Points: 35,840, Level: 1 Points: 35,840, Level: 1 Points: 35,840, Level: 1
Activity: 54% Activity: 54% Activity: 54%
UK CHRYSLER 300C's Avatar
Member Number: 12398
I can't help with cheap sh1t alternators but I can help with replacing it....in way less time than 18 hours...guaranteed....
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
Battery Light Question DWEW European & Diesel Powered 300 Models 31 08-02-2012 03:50 PM
Intermittent HVAC Position Selector Light (tap it enough and it works) CDN300T General Discussion on Issues / Trouble Shooting 4 09-30-2011 04:34 PM
Battery light, followed by transmission limp home, followed by engine light buddygunz European & Diesel Powered 300 Models 2 04-16-2011 11:35 AM
Intermittent Airbag light dave699 European & Diesel Powered 300 Models 7 09-19-2010 08:09 PM
Battery Light!!!! Ukyo Yoshiro Problems / Dealer Service 6 09-04-2006 01:21 PM
