Intermittent Battery Light - Page 9 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 12-07-2012, 03:10 AM   #81 (permalink)
Points: 1,972, Level: 1 Points: 1,972, Level: 1 Points: 1,972, Level: 1
matrix1975's Avatar
Car: 2008 Chrysler 300C CRD [YNK]
Member Number: 27470
Well, I finally got around to disassembling my alternator. There was a small amount of the carbon based sludge around the brushes and slip rings. One thing I did notice though and is significantly different to my original alternator is that the "disc" inside the alternator behind the pulley is all rusty. So I am wondering if the alternator has gotten wet possibly?
Re-installed alternator yesterday morning. Blimey it was cold. Didn't get much further as on inspecting the drive belt it's starting to split, so will replace that whilst it's all apart.
matrix1975 is offline
Old 12-07-2012, 03:30 AM   #82 (permalink)
Points: 25,800, Level: 1 Points: 25,800, Level: 1 Points: 25,800, Level: 1
Member Number: 37145
Did you fit a new regulator/brush pack to the old alternator or fit another new alternator?
Regards
Simon
www.custom300cshop.co.uk
Old 12-07-2012, 04:11 AM   #83 (permalink)
matrix1975's Avatar
I fitted a new regulator/brush pack to this alternator. The slip rings were ok. So fingers crossed it's going to be ok. There wasn't a great deal of the carbon based sludge.
I still have my old original dead alternator where the slip rings have a piece of the copper plate missing from them.
I did wonder whether it was real copper plate or whether it was something along the lines of this:
FE-5100-5276-7 - 3M - 1181 TAPE, COPPER FOIL, 6MM X | Farnell United Kingdom
Old 12-07-2012, 07:35 AM   #84 (permalink)
Major Contributing Member
Points: 6,033, Level: 1 Points: 6,033, Level: 1 Points: 6,033, Level: 1
Activity: 87% Activity: 87% Activity: 87%
Member Number: 28359
Don't know if your joking or not, but will be solid copper. Not copper plated. Just a poorly designed alternator which doesn't allow debris to get blown away.
Jack
jackwalton is offline
Old 12-07-2012, 08:07 AM   #85 (permalink)
Points: 7,897, Level: 1 Points: 7,897, Level: 1 Points: 7,897, Level: 1
devilmaycare's Avatar
Member Number: 7282
There's a wealth of information on the Web concerning alternator re-conditioning, including slip-ring replacement, which doesn't look too difficult if you can use a soldering iron. Replacement parts are surprisingly inexpensive and if I had a spare "dead" alternator on my hands, I would be tempted to have a go.
devilmaycare is offline
Old 12-07-2012, 08:46 AM   #86 (permalink)
matrix1975's Avatar
18 months ago when i saw the slip rings had copper missing, I just assumed it was something that was terminal and went and bought a new alternator. I'll have a look at reconditioning the one I assumed was "dead". Cheers.
Wasn't joking, I really did assume they were copper plated, due to the layer of copper appearing to be so thin and whatever occurred in the alternator it had managed to strip it off.
Old 12-07-2012, 09:07 AM   #87 (permalink)
It may not be to much of a problem fitting a slip ring and regulator to an old alternator. The only issue is the hours fitting it and hoping it works afterwards, unless you can find somewhere that could test it for you before fitting it.
Is this slip ring anything like it? http://www.jcrsupplies.co.uk/product...EF_135179.html
Old 12-07-2012, 10:42 AM   #88 (permalink)
matrix1975's Avatar
Just watched this video on replacing Slip Rings on a Valeo alternator.
I now see why my assumption that slip rings were plated is so ridiculous after seeing the 'old' ones that came off and the 'new' ones that went on.
Thanks for the link Simon. Yes, it's not an easy task to take the alternator off and put the reconditioned one on just to test! I'm sure I can find a local auto electrician who would be able to bench test one.
Cheers for the advice all! I may well have a crack at resurrecting my old once assumed dead alternator after I've got my C back on the road.
The Following User Says Thank You to matrix1975 For This Useful Post:
badgx (12-07-2012)
Old 12-07-2012, 03:55 PM   #89 (permalink)
Points: 30,136, Level: 1 Points: 30,136, Level: 1 Points: 30,136, Level: 1
badgx's Avatar
Member Number: 32952
Great video
badgx is offline
Old 12-08-2012, 04:01 AM   #90 (permalink)
Originally Posted by badgx View Post
Great video
I'll second that.
Really good Video, well worth watching all way through.
Better than X Factor. Lol
Jack
Battery Light Question DWEW European & Diesel Powered 300 Models 31 08-02-2012 03:50 PM
Intermittent HVAC Position Selector Light (tap it enough and it works) CDN300T General Discussion on Issues / Trouble Shooting 4 09-30-2011 04:34 PM
Battery light, followed by transmission limp home, followed by engine light buddygunz European & Diesel Powered 300 Models 2 04-16-2011 11:35 AM
Intermittent Airbag light dave699 European & Diesel Powered 300 Models 7 09-19-2010 08:09 PM
Battery Light!!!! Ukyo Yoshiro Problems / Dealer Service 6 09-04-2006 01:21 PM
