Originally Posted by UK CHRYSLER 300C
Looks like you gotta bite the bullet mate,if it needs updating it can only be done with a Starscan,sorry.
Nice meeting you too,told you my place would be manic and cars and customers everywhere....and bloody cold ay.....lol
It was freezing !!
Will let have Chrysler have a stab at it! But reading the forums it seems that Chrysler are useless in finding p0300 code issue. There has been a TSB 09-010-06 on carbon buildup which prevents the valves rotating and they have designed new springs and recommend carbon cleaner
http://oskin.ru/pub/chrysler-dodge/m...isfire.pdf.pdf
OTHERWISE LONG ( £££££ ) LIST OF
"P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open".
