300c LED Ghost Shadow Projector Lights - opinions please - Page 10 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 11-29-2012, 10:57 AM   #91 (permalink)
Points: 42,481, Level: 1 Points: 42,481, Level: 1 Points: 42,481, Level: 1
Activity: 91% Activity: 91% Activity: 91%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Member Number: 21130
Originally Posted by tim@thecustom300cshop View Post
Fitted one in my front door card this arbo. The fitting of the projector itself isn't too bad with exception of the hole saw/hole being a tad small and I needed to file it a little larger. Cut the supply to the stock puddles since these are replacing anyway and just popped the lens back in. I've also taken a supply from the stock puddle into the car so I can install/wire projectors in the back doors.
More pic's to come as I have them
they look nice & bright, but its hard to tell if the blurring is in the projector, or bum photographs!
did it break your heart to cut the metal?
Watching You Avoiding Me!
Kaiser Bill is offline
Old 11-29-2012, 11:40 AM   #92 (permalink)
Points: 30,201, Level: 1 Points: 30,201, Level: 1 Points: 30,201, Level: 1
tim@thecustom300cshop's Avatar
Car: 2006 Chrysler 300c CRD
Member Number: 37143
No, bum photographer Miles. On the night setting my camera takes a lifetime to take (gather light I guess) and its hard to keep still as its capturing the image.
The images in reality are crystal clear.
Got a supply from the front panel/puddle light inside the car so'll be putting in the back doors also. Tried taking a supply from the interior light on/off/dimmer switch (next to fog switch) presuming it was the white/yellow but it wasn't giving a supply. One of those wires on that plug must be a supply since the switch does control the int. lights, but it was too cold to stay out there all afternoon with a meter.
Looking at the backs though they'll either have to go way forward (may cut the image projection) or mount within the cubbly hole area, probably go for the latter as they won't really be seen even though they'll exposed within the cubby hole.
I may also mount one centrally under the rear bumper, linked up to the boot light.
Cut metal?? I drilled the door card so no metal.
www.custom300cshop.co.uk
Tints¦Clear Sidemarkers¦Startech 22" Rims, Front Splitter & Boot Spoiler¦Mopar Ovals & Shields¦Mopar Grille¦Billet Tech Catch Can¦Stormtech Rear Diffuser & Sideskirts¦MyGig Upgrade with Lockpick¦Viezu 305bhp/538lbsft Torque Performance & Blueoptimize Remaps with V-Switch¦Intercooler Upgrade¦Sonar LED Tail Lights¦DRL's¦Front & Rear Cameras¦De badged Boot Lid¦Blue LED Interior Light Conversion¦Mopar Ghost LED Projector Puddle Lights¦
tim@thecustom300cshop is offline
Old 11-29-2012, 11:48 AM   #93 (permalink)
Originally Posted by dadsincharge View Post
How long did it take you Tim?
Ages, well not the actual projector. I was faffing for ages trying to get a supply firstly from the int. light switch/dimmer then from the door card through the rubber harness cover (car side) through to somewhere I could grap it. I'd presumed there was just wires running through from the door and into the car but as far as I could feel its a plug so my plan to run a supply through the rubber and into the car didn't pan out as expected.
I reckon you could probably fit a pair using the puddle light supply within an hour easy. Just undo the screws and fixings holding the door card on allowing you to drill the hole, pull the bottom out and get your hand through to position and fasten the projector, wires through to the stock puddle position and job done. As I mentioned though the hole saw could do with being a couple of mm's larger really since I needed to file out the hole a tad to get the projector through.
Old 11-30-2012, 03:35 PM   #94 (permalink)
Points: 8,737, Level: 1 Points: 8,737, Level: 1 Points: 8,737, Level: 1
300 hemi's Avatar
Car: 2008 Chrysler SRT8 Touring (DEM)
Member Number: 21645
Both fitted but need to look at one again as every time I shut the door it moves position.
Blue Facelift 08 SRT-8
K&N CAI
93 CAI Predator tune
EBC Turbo Groove Rotors
EBC Yellow Stuff Pads
180 tstat
Clear Side markers with LED bulbs
LED sidelights
BT catch can
Vredestein 245/45/20 on front
Vredestein 275/40/20 on rear
JC Weldfab Custom 3" Exhaust With 4" Tips
300 hemi is offline
Old 11-30-2012, 03:54 PM   #95 (permalink)
Glad you got them. Got to revist mine also as I mounted one just a fraction too close to the door so the projected image has the very top of the circle cut. Couldn't see the image clearly enough in the daylight so didn't notice. Was going to do today but ended up calling out the RAC as I couldn't get in to it. Battery wasn't totally dead but flat enough so it wouldn't operate the central locking. Must have been the 3 or 4 hours I was messing about with it yesterday. Surprised it doesn't have a charge point or at least a connection point/wires somewhere accessible like under the wheel arch or somewhere, just somewhere you could connect an external battery to, to get enough juice into the system in an emergency to operate the central locking. Don't think it would aid a thief.
Old 11-30-2012, 04:27 PM   #96 (permalink)
Points: 27,624, Level: 1 Points: 27,624, Level: 1 Points: 27,624, Level: 1
chrisp's Avatar
Car: 2006 Chrysler 300c SRT-8 {SZZ}
Member Number: 20152
What about the jump start points under the bonnet ? Tim
MOPAR OR NOCAR 440 Coronet
2006 SRT8 Diablo Predator 93 Octane CAI performance tune
Mopar Cold Air Intake
EBC Yellows
Hurst Shifter
Badlanz Cutouts
chrisp is offline
Old 12-01-2012, 01:42 AM   #97 (permalink)
Major Contributing Member
Points: 13,933, Level: 1 Points: 13,933, Level: 1 Points: 13,933, Level: 1
RichardMS's Avatar
Car: 2008 Chrysler 300C SRT Design Touring (RMS)
Member Number: 7572
Mine were delivered yesterday, hope it is fine Tuesday to have a play.
RichardMS is offline
Old 12-01-2012, 08:05 AM   #98 (permalink)
Points: 2,049, Level: 1 Points: 2,049, Level: 1 Points: 2,049, Level: 1
Car: 2008 Chrysler 300C SRT Design (CLU)
Member Number: 38399
Got mine Friday and fitted today. Took about 45 mins on passenger side and 15 mins drivers side. I drilled into the door card leaving the puddle lights as is. Hardest part was trying to tighten the nut - big hands and little space. Will try to put a pic up when it gets dark.
Blue LED's for interior
White LED's for side lights (in headlights) and License plate
Blue car mats with 300C SRT embroidered
Viezu Stormtech tune - 303bhp/508lbsft torque - Switchable to BlueOptimize map via V-Switch (through Custom 300C Shop)
SRT Design Ghostlights in front doorcards
2013 Maps
Software: 2.404
GraceNotes: 4621
dadsincharge is online now
Old 12-01-2012, 01:24 PM   #99 (permalink)
No one else brave the cold to get em fitted??
Tried for the back doors but they're pretty well a no go I reckon. The underside lip isn't in itself wide enough because of the inside cubby hole (when looking inside the panel). Did think about mounting them higher up, next to the handle which would be ok but the projected image is too large and shines over the door sill etc. May revisit it again when its warmer. One under the rear bumper coming on with the boot light is next for me.
Old 12-01-2012, 02:11 PM   #100 (permalink)
300 hemi's Avatar
Couple of pics from last night photos don't do it justice. One from each side and one with a flash.
300 hemi is offline
Projector Fog Lights? phillips2024 Lighting Discussion 17 11-27-2006 08:52 AM
Projector Fog Lights Jerry M. Lighting Discussion 9 01-09-2005 11:00 PM
