Ditto, broke some too... (plastic pop rivet fasteners). The prob with them seems to be if the hole isn't exactly lined up i.e. when you push the tab in to release it, it's prongs are still 'hanging on inside' so when you go to ease it out it just snaps. Don't think the cold helps with plastic either.
Re your puddle light lenses Chrisp, tbh I'd be inclined to as you say remove the 4 lower screws then cut the wires to the light close'ish to the lens/bulb, you can then pull it down and will have enough to connect the new projector wires. If not you can pull the clip off that's holding the loom which'll give you more. At the end of the day would we really go to the lengths of connecting the original puddles up anyway? hence why I wasn't too concerned about cutting the stock puddle wires.
