Fault Codes Ahoy! - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 11-09-2012, 10:35 AM   #1 (permalink)
Points: 2,491, Level: 1 Points: 2,491, Level: 1 Points: 2,491, Level: 1
Car: 2007 Chrysler 300c Touring CRD
Member Number: 20049
Fault Codes Ahoy!
Happy Friday to the knowledgeable 300C owners,
My 300C has resigned itself to limp mode and I have got the following out of the fault box:
P1270 Intake Manifold Runner Control, Performance, Intermittent
P0675 Cylinder 5 Glow Plug Circuit, Intermittent
P0674 Cylinder 4 Glow Plug Circuit, Intermittent
P0671 Cylinder 1 Glow Plug Circuit, Intermittent
ECU E8, P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range.Perf...
U140A Front Right Speed Sensor, Implausible Signal
On the simple ones I have some fresh Glow Plugs currently lost in Royal Mail somewhere (were supposed to arrive yesterday and have not come in today's post either). Would like to clear the rest.
Guessing the speed sensor one is why the ABS lights up when I turn sharply in the rain, though may be wrong. Help with that and the Manifold issues would be superb (please)
Chrysler 300C Touring Lux, Black, CRD, Startech Grill, Sat Nav, Boston Premium Sound System, Parrot and a boss tow bar
Needs the following: Working lights, Speakers to Stop Rattling, Spare Key
sibeer is offline
Old 11-09-2012, 01:00 PM   #2 (permalink)
Looking into the P1270 and P2015 it looks like a swirl motor resistor mod may be in order. Hopefully driving it home from work tonight and then to Maplins tomorrow isn't too risky.
sibeer is offline
Old 11-09-2012, 01:05 PM   #3 (permalink)
Major Contributing Member
Points: 7,758, Level: 1 Points: 7,758, Level: 1 Points: 7,758, Level: 1
devilmaycare's Avatar
Member Number: 7282
Yes. Anything linked to this descriptor generally points to swirl motor problems.
Do you also have the engine check lamp on?
Last edited by devilmaycare; 11-09-2012 at 01:07 PM. Reason: Engine check lamp query added.
devilmaycare is offline
Old 11-09-2012, 03:21 PM   #4 (permalink)
Points: 5,051, Level: 1 Points: 5,051, Level: 1 Points: 5,051, Level: 1
Activity: 84% Activity: 84% Activity: 84%
Member Number: 28359
Thats a lot of problems all at once?
I would have a good look around cable looms for signs of rubbing/chaffing before looking to change anything.
I'm not saying you haven't got some parts that need changing, but 300C's do suffer from fairly frequent cable chaffing problems.
Jack
jackwalton is online now
The Following User Says Thank You to jackwalton For This Useful Post:
Simon@thecustom300cshop (11-10-2012)
Old 11-09-2012, 04:21 PM   #5 (permalink)
Points: 27,206, Level: 1 Points: 27,206, Level: 1 Points: 27,206, Level: 1
badgx's Avatar
Member Number: 32952
You could try clearing the codes to see which ones rush back on the system as solid state, should illuminate any ghosts codes but keep a eye in case they come back later? Somebody did suggest the swirl motor mod, worth looking into? Good luck
badgx is online now
Old 11-11-2012, 04:57 AM   #6 (permalink)
Did a wipe and reset prior to this and these are what came back up.
In dash lights I first got a flashing red lightning that came on once driving. Then the yellow engine light came on. It went off at the end of the journey. but when it restarted it had the yellow light on from the of and the red one didn't come on.
Will check the wiring too.
sibeer is offline
fault codes on 2011 300 oly2 2nd Generation Chrysler 300 Discussion 3 08-27-2012 07:42 PM
fault codes paul faucette General Discussion on Issues / Trouble Shooting 3 08-11-2012 04:34 PM
Fault codes hbaydiesel European & Diesel Powered 300 Models 2 06-14-2011 05:55 AM
Help Me Work Out These Fault Codes :) h3rjp European & Diesel Powered 300 Models 3 03-03-2010 09:56 AM
Fault codes for dummies??? wildmark Performance General Discussion 3 01-04-2008 11:07 AM
