body control module bcm location - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 11-15-2012, 04:32 AM   #11 (permalink)
Points: 25,800, Level: 1 Points: 25,800, Level: 1 Points: 25,800, Level: 1
Member Number: 37145
Originally Posted by bucket28 View Post
Hi all again, simon I had high hopes this morning but guess what its still the same, tried disconnecting battery to reset lasts for about 5 secs then all lights back on. If someone is able too supply a wiring diagram i would be eternally grateful or even know I link to one.
Thanks for everyone's input so far
Don
Thats a bugger, that normally does the trick. Please let us know what it was when you find the cause.
Regards
Simon
www.custom300cshop.co.uk
Old 11-15-2012, 08:44 AM   #12 (permalink)
Major Contributing Member
Points: 6,045, Level: 1 Points: 6,045, Level: 1 Points: 6,045, Level: 1
Activity: 84% Activity: 84% Activity: 84%
Member Number: 28359
See attached drawings which are a starting Point.
If you send me a Private Message with your email address I think I can help with info.
I would check the Front Control Module First if I was looking for fault.
Jack
body control module bcm location-capture.jpg   body control module bcm location-capture-1.jpg
jackwalton is offline
Old 11-15-2012, 09:57 AM   #13 (permalink)
Points: 151, Level: 1 Points: 151, Level: 1 Points: 151, Level: 1
Car: 2006 chrysler 300c
Member Number: 41463
You are a star jack that's exactly would I was looking for, on other jobs the now but will let you know how I get on any more info please send to my email. bucket@onetel.com
Thanks again
Don
bucket28 is offline
Old 11-15-2012, 10:44 AM   #14 (permalink)
Thanks again
Don
Was gonna email you a Pdf manual but file is too big and will not send, Sorry.
I think you've got the relevant bits for now though.
If you struggle I may be able to extract the relevant bit but I havn't got the software for splitting the file. I feel sure I could do it if it becomes necessary but I don't like loading new Software on Computer unless its essential.
Jack
Old 11-15-2012, 03:10 PM   #15 (permalink)
Hi jack do you have diagram with the instrument cluster in loads of ecu's with no coms with cluster and its the only ecu my diagnostic machine won't talk to. Fault codes I have are in pcm U110a lost comms with scm can c
Abs u0126 lost comms steering angle sensor
Airbag u0208 and u0209 lost comms with seat modules u0186 with audio amp u0212 with steering column control module u0155 with instrument panel
Bcm u1107 ecu in single wire mode u0019 low speed can communication bus u110a lost comms with scm can c
Wcm u0155 lost comms with instrument panel etc etc
Sorry for the long list just in case it springs something into place
Thanks
Don
bucket28 is offline
Old 11-15-2012, 03:28 PM   #16 (permalink)
Points: 36,622, Level: 1 Points: 36,622, Level: 1 Points: 36,622, Level: 1
Activity: 76% Activity: 76% Activity: 76%
UK CHRYSLER 300C's Avatar
Member Number: 12398
Where are you located as I know someone with a diagnostic tool that will read your car....
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
Old 11-15-2012, 04:00 PM   #17 (permalink)
haha i'm afraid i'm a bit far away if you look on your map of the uk at the very top left i stay on an island called the isle of lewis, hence the hassle of not being able to go to my local chrysler dealer but if anybody wants to come on holiday and fix this car .... :-)
bucket28 is offline
Old 11-15-2012, 04:43 PM   #18 (permalink)
Sorry to be a pain again jack but do you have a diagram like above for can b bus
Thanks
bucket28 is offline
Old 11-15-2012, 06:33 PM   #19 (permalink)
Thanks
See attached for CAN B Bus Don.
Old 11-26-2012, 05:33 PM   #20 (permalink)
Thought I'd better get back in touch and but and end to this problem, by disconnecting each ecu and the fact there was no comms traced fault to instrument cluster customer didn't want to buy new so sourced a second unit finally after nearly two weeks arrived today fitted and all OK. Hope this helps someone in future. Huge thanks to Jack and everyone else that helped
Don
bucket28 is offline
Tags
bcm body control module
Control module adrianna123 General Discussion on Issues / Trouble Shooting 7 09-07-2012 12:48 PM
F/S: Jet performance control module jdm1984 Parts Buy/Sell Forum 1 10-09-2011 11:49 PM
Wireless Control Module Odo European & Diesel Powered 300 Models 15 10-05-2011 01:16 PM
Jet performance control module jdm1984 Pacific Northwest Forum 0 09-28-2011 09:02 PM
06 300 Uconnect module location Strickzaine Car Audio/Alarms/UConnect/Navigation 4 02-21-2011 08:46 AM
