**** Main beam - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 11-18-2012, 05:52 AM   #21 (permalink)
Points: 27,755, Level: 1 Points: 27,755, Level: 1 Points: 27,755, Level: 1
badgx's Avatar
Member Number: 32952
OK, after a long search on Google regarding high beam and linking up with other sites and forums, I have found 2 possible upgrade solutions, which will increase high beam output.
Solution 1
This is the most cost effective upgrade. Replace high beam bulb 9005 (HB3), with uprated 100 watt bulbs.
I checked wiring and plugs and checked the fuse. The wiring is OK to take on the extra power and the original fuse rating for the high beams at 20A is OK. TBH, you can plug in 10A fuse and still get away without it blowing.
I found a link here although there may be other bargains. Its a pair of 9005, plus comes with 2x sidelights. Its apparently coated which is to help filter some of the yellow but I'm sure the coating will eventually fade off.
Solution 2
This is expensive! but it will get the closest desired effect for a HID solution for your high beams, little or no warm up time its fast enough for a flash.
Parts required, a pair of OEM replacement D4S ballast. Denso has been recommended a few times on various forums and I know of this brand can be found on our cars e.g. alternator and the front wind shield wipers motor. It has a very shortest warm up time, ideal for flash.
Also a pair of AMP D4S harness and a pair of HID 9005 bulb is needed to complete the project. The ballast is the most expensive part, which makes it an expensive mod!!!
For now, I've gone with the Solution 1, so lets see how that goes
But anyone here for Solution 2 I have added a video here of D4S Denso ballast, the igniter is build in and the rest is plug and play.
Good luck
**** Main beam-1badgx.jpg   **** Main beam-2badgx.jpg   **** Main beam-3badgx.jpg
badgx is offline
The Following User Says Thank You to badgx For This Useful Post:
dannyfiveforty (11-24-2012)
Old 11-18-2012, 09:05 AM   #22 (permalink)
Major Contributing Member
Points: 14,657, Level: 1 Points: 14,657, Level: 1 Points: 14,657, Level: 1
Armchair's Avatar
Car: 2009 Chrysler 300c crd SRT Design
Member Number: 28455
Not sure I like the yellow health warning..."Dicking around with this box can cause injury or death."
Armchair is online now
Old 11-18-2012, 11:25 AM   #23 (permalink)
badgx's Avatar
I think like with many generic ballasts, risks of personal injury is very low as long as care is taken during installation process, like disconnecting the battery. Some basic practical & electrical knowledge helps
As for the technical side, the ballast will need to be mounted to the vehicle and 2 wires for + (ive) & - (ive) will need to be spliced to vehicle loom. The high beam are fused at 20amps, which is the correct rating for HID's, same like factory d1s ballast, which is mounted on the underside of the headlight housing.
For now I've gone with a bulb upgrade to 100 watts, its a lot cheaper and I think should give a higher output than stock. Lets see how it goes, watch this space
Good luck
badgx is offline
Old 11-18-2012, 02:22 PM   #24 (permalink)
Points: 42,459, Level: 1 Points: 42,459, Level: 1 Points: 42,459, Level: 1
Activity: 95% Activity: 95% Activity: 95%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Member Number: 21130
I have a cheap set of HID main beams at 4300K (35W....goodness knows what 55W are like...melt the road, probably!). They take a few seconds to get to full strength when newly switched on, and they can cool-off to that position after about 3 minutes of having them off (when using dipped only). Its not too much of a problem though, as the dipped beam stays on to provide some light until theyre warm. Having said that, when they do get to full strength its like daylight for 150 yards. May sure you get canbus versions....I swapped a non-canbus ballast in & it switched off after 3 secondS
This is the make I went for...they keep reasonably priced spares HB3 9005 CANBUS SOLVED 35w HID CONVERSION KIT 4300k UK | eBay . You can do this a lot cheaper using a cheap kit & a canbus wiring harness....I've only used a cheap non canbus kit in the reversing lights (theyre durable kits), so I cant say how good the canbus wires are.
cheap kits, eg http://www.ebay.co.uk/itm/Xenon-Slim...item19d6d974e1 plus canbus solvers eg http://www.ebay.co.uk/itm/2x-Xenon-H...item43ae5fafcf
just one thing....make sure you get an air gap between any wires/parts. I just pushed my first harness in any old way, so wires touched the back of the bulb....and I melted the bulb's backside. Since then, no issues (ie a period of 18 months or more)
Watching You Avoiding Me!
Kaiser Bill is offline
The Following User Says Thank You to Kaiser Bill For This Useful Post:
Simon@thecustom300cshop (11-18-2012)
Old 11-24-2012, 02:41 PM   #25 (permalink)
Points: 16,343, Level: 1 Points: 16,343, Level: 1 Points: 16,343, Level: 1
Activity: 43% Activity: 43% Activity: 43%
dannyfiveforty's Avatar
Member Number: 33586
Thanks for all your help guys, has given me a lot to think about, I will probably just upgrade my lamps for now though and see how I feel after Xmas. badgx, how did you find solution 1 worked for you? A lot better? Many thanks
dannyfiveforty is online now
Old 11-24-2012, 03:15 PM   #26 (permalink)
Points: 2,833, Level: 1 Points: 2,833, Level: 1 Points: 2,833, Level: 1
Member Number: 41160
HB3 100w Xenon Main Beam Headlight Bulbs RENAULT CLIO 2004 To 2006: Amazon.co.uk: Car & Motorbike
looking for a pair of 5W5's today and saw the above are standard stock at Halfrauds...£16.99 each.
i did wonder at the time if they would be suitable main beam replacements
Pappajohn is offline
Old 11-24-2012, 03:35 PM   #27 (permalink)
Points: 54,979, Level: 1 Points: 54,979, Level: 1 Points: 54,979, Level: 1
Car: Chrysler 300c 2009 CRD
Member Number: 37144
Bite the bullet and get a HID kit for about £40.....canbus friendly
www.custom300cshop.co.uk
Old 11-24-2012, 03:54 PM   #28 (permalink)
Don't like the idea of warm up time though... :S
Old 11-24-2012, 04:00 PM   #29 (permalink)
they aint that slow, have a look at someone's with them, then make your mind up
Old 11-25-2012, 02:26 AM   #30 (permalink)
Points: 13,933, Level: 1 Points: 13,933, Level: 1 Points: 13,933, Level: 1
RichardMS's Avatar
Car: 2008 Chrysler 300C SRT Design Touring (RMS)
Member Number: 7572
What colour temp did you go for Paul?.
Will these do?, CANBUS XENON HID CONVERSION KIT H7 H1 H4-2 H4-3 HID Cool ERROR FREE 6000k/8000k | eBay
RichardMS is offline
Main Beam Deflectors ??? - Driving in France derick European & Diesel Powered 300 Models 31 01-31-2010 05:23 AM
main beam-which bulbs keat European & Diesel Powered 300 Models 11 10-10-2009 07:25 PM
Main Beam is Pants keat European & Diesel Powered 300 Models 23 02-25-2009 02:25 PM
Main beam weak? Agusta European & Diesel Powered 300 Models 16 12-22-2008 06:25 AM
Hid And Matching Main Beam And Spots UK CHRYSLER 300C Appearance General Discussion 6 07-29-2007 12:26 AM
