Headlamp module? - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 11-27-2012, 09:39 AM   #1 (permalink)
Points: 3,116, Level: 1 Points: 3,116, Level: 1 Points: 3,116, Level: 1
Car: 2008 (facelift) Chrysler 300 CRD (Lux Pack) "UVU"
Member Number: 37792
Headlamp module?
So my car has been to a local Pendragon group dealership to investigate why my offside headlamp is not working. I know it is not the bulbs as I switched them and they have found a fault code B167B.
They say it is not the ballasts and that it is a module which is part of the headlamp assembly.
I have checked my warranty and lamp units are not covered, can the module be obtained separately, are they talking sh*te?
A new headlamp assembly (complete with "module") is £600.00 probably plus vat and fitting, if I can get the "module" separate then that is covered
Mods so far:Genuine Chrysler floor mats, alternator shield, 20% front 75% rear Llumar window tints, Brink detachable tow bar, internal boot release handle.......
must spend more money, must spend more money, must spend more money.............
(repeat until broke)
grandtrousers is offline
Old 11-27-2012, 11:27 AM   #2 (permalink)
Points: 25,800, Level: 1 Points: 25,800, Level: 1 Points: 25,800, Level: 1
Member Number: 37145
I have an old offside headlight in pieces and the only thing I can see inside it is a ballast and leveller motor. The only headlight module I know of is located behind the offside headlight near the windscreen washer filler neck but the headlights still work when that is disconnected.
That code means B167B=RIGHT FRONT HEADLAMP LIGHT SOURCE CIRCUIT.
Regards
Simon
www.custom300cshop.co.uk
The Following User Says Thank You to Simon@thecustom300cshop For This Useful Post:
grandtrousers (11-28-2012)
Old 11-27-2012, 04:27 PM   #3 (permalink)
Points: 30,136, Level: 1 Points: 30,136, Level: 1 Points: 30,136, Level: 1
badgx's Avatar
Member Number: 32952
Charltons Auto Recycling Centre in Cambridge may have it in stock, although I think it will cost a tonne. They should be able to deliver parts by post and most items come with 99 day warranty.
badgx is offline
Old 11-27-2012, 05:37 PM   #4 (permalink)
Still not sure about the "inbuilt" headlamp module
Old 11-28-2012, 04:47 AM   #5 (permalink)
badgx's Avatar
Do the headlights dance OK?
badgx is offline
Old 11-28-2012, 04:58 AM   #6 (permalink)
These pictures are of the inside of an offside headlight from a 2008 Facelift car. Just followed the wiring inside it and theirs only a ballast and level motor.
Leveller motor
Ballast
Old 11-28-2012, 09:24 AM   #7 (permalink)
I will take this very detailed and clear evidence and show it to the garage.
Old 11-28-2012, 11:13 AM   #8 (permalink)
badgx's Avatar
In a nutshell, if the headlight dance work then the motor is fine and if the hids work, then the ballast is fine.
The motor is the thing that make the beam move up and down and makes the lights dance, which is not accessible! You cannot take the headlight apart unless you baked it in the oven to soften the glue that seals it all together, these are not serviceable parts.
As long as beam setting is aligned at MOT and the lights are working then all is well. With regards to the code, ask them to clear it. Ignore it if it crops back unless you encounter a visible failure at the MOT
Good luck
badgx is offline
Old 11-28-2012, 12:12 PM   #9 (permalink)
Good luck
I think GT's problem is the offside light doesn't light and its not the bulb. I'm thinking either the ballast is not getting any power or the ballast is screwed.
grandtrousers (12-23-2012)
Old 11-28-2012, 12:48 PM   #10 (permalink)
badgx's Avatar
If there is NO light after bulb swap test, best if GT could check the fuse. Its an 08' model, what's the fuse number location for off side circuit? It should be to the front fuse distribution block, unfortunately my handbook has gone walkie's. There is also an igniter but one side is working well, so then it may point towards a fault with the ballast itself assuming all connections are good
As Simon photo demonstrates the ballast is mounted to the under of the headlight. To gain access to this the front bumper will need to be removed and then the headlight dismounted. Its an easy job, whole lot with some basic tools should take no more than an hour. Just need a bit of confidence and 3CF!
Regrettably if the fault is with the ballast, you are looking at £££ for the OEM ones.
badgx is offline
New TSB: Flash: UConnect Hands Free Module Fails To Respond Due To Module "Lock Up" ResumeSpeed Problems / Dealer Service 9 03-30-2013 03:28 PM
lost communication with headlamp leveling control module slerssi79 General Discussion on Issues / Trouble Shooting 1 08-23-2012 10:31 AM
HID Headlamp Flicker sdm197 European & Diesel Powered 300 Models 7 06-02-2008 06:14 AM
headlamp washers Chamby1 Problems / Dealer Service 16 04-03-2006 06:31 PM
Where to buy those VIP headlamp covers? Jameselwell Appearance General Discussion 10 02-03-2006 11:04 PM
