Possible charging fault cause - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 12-01-2012, 05:33 AM   #21 (permalink)
Major Contributing Member
Points: 7,897, Level: 1 Points: 7,897, Level: 1 Points: 7,897, Level: 1
devilmaycare's Avatar
Member Number: 7282
The battery seems OK, looking at cranking volts and no starting difficulties.
devilmaycare is offline
Old 12-01-2012, 06:45 AM   #22 (permalink)
Points: 3,061, Level: 1 Points: 3,061, Level: 1 Points: 3,061, Level: 1
Member Number: 41160
Originally Posted by Simon@thecustom300cshop View Post
The flickering lights could just be the alternator struggling to keep the voltage up whilst the heater is on. I think pulling fuses is worth a try. Does the code reader your waiting for do more than just engine codes and running functions?
really not sure until i get it Simon.
Pappajohn is offline
Old 12-01-2012, 06:48 AM   #23 (permalink)
Originally Posted by badgx View Post
Can you be sure the mechanic replaced the alternator? Does it look new or just cleaned and serviced up?
Check & top up distilled water at your batteries, whilst a solution is found
definitely replaced as i did it myself
battery was checked a couple of weeks ago, needed a little water but very little and its an 800cca tested at 675cca @around 12v when the alternator was failing.
Old 12-01-2012, 10:24 AM   #24 (permalink)
Member Number: 7282
Originally Posted by jackwalton View Post
I always thought the regulator was in the Alternator too, but it appears that the ECU does the voltage regulation according to w/s manual.
Unless there is a regulator in the Alternator and the ECU does the final logic control depending upon which devices are turned on ??
Jack
The "standard" alternator does incorporate a regulator, but maybe the ECU also plays a part.
Some more diagnostic suggestions:
1. The cabin heater should only be energised when the engine is cold. Check water temp reading to confirm temp sensor is OK. Also, check ambient (air) temp on EVIC in case this also plays a part.
2. The following fuses relate to the cabin heater:
a) Front Engine Compartment: Cavity #14, 25A Clear, Cabin Heater/Engine Control Module (ECM). This fuse controls the relays, which switch the 3 heating elements.
b) Rear PDC (near battery): Cavities #1,2,3, 50A Red, Cabin Heater (each of 3 elements fused separately).
I think I would just try pulling fuses #1,2 and 3, which should completely disable the heater to confirm whether this is the culprit or not.
Correction to 2b: Location is under cowl cover at front.
Old 12-01-2012, 11:07 AM   #25 (permalink)
not disagreeing with you, but my handbook says the diesel specific cabin heater fuses are under the cowl cover next to the brake fluid reservoir....3 x 50amp.
a job for another day.
The Following User Says Thank You to Pappajohn For This Useful Post:
devilmaycare (12-01-2012)
Old 12-01-2012, 11:28 AM   #26 (permalink)
Points: 25,800, Level: 1 Points: 25,800, Level: 1 Points: 25,800, Level: 1
Member Number: 37145
I don't know about fuses but there are some relays in there on CRD's.
Regards
Simon
www.custom300cshop.co.uk
Old 12-01-2012, 11:48 AM   #27 (permalink)
Member Number: 7282
Apologies! You are absolutely correct. I was mislead by the page heading (Rear PDC) and the photos (which did not include cowl cover), although I should have been suspicious of such heavy fuses being so far removed from the component they were protecting.
The Following User Says Thank You to devilmaycare For This Useful Post:
Pappajohn (12-01-2012)
Old 12-01-2012, 11:52 AM   #28 (permalink)
maybe have a look tomorrow if SWMBO has nothing else planned
Old 12-02-2012, 05:54 PM   #29 (permalink)
Points: 30,136, Level: 1 Points: 30,136, Level: 1 Points: 30,136, Level: 1
badgx's Avatar
Member Number: 32952
OK, then the only last thing you could check is the headlight switch, that's for the flickering you mention to the dash and lights.
I found this thread, you may want to pm FISCH to see how he got on with the switch
Lighting issues - started going off and on...
badgx is offline
Old 12-04-2012, 02:57 PM   #30 (permalink)
thanks for the heads up and link but i doubt it's the switch.
the dash lights dont go out and on again....more like one second they get full voltage then next second they are getting 6 volts then back again next second and so on until the engine is warmed up and voltage increases again to 14+ volts which points me to the 'cold' engine electric heater elements pulling a very high current until the engine temp sensor tells them to turn off.
if i don't use the heater at all until the engine is up to normal temperature then everything works fine, 14 plus volts and no lights flickering, so i still suspect the heater, or more specifically, the electric cabin heater.
the cabin heater has 3 separate elements totalling 1000 watts (1kw), all controlled by 3 x 50amp fuses...if they all draw a max 50amps then thats around 80% of the alternators maximum output.
next job is remove the scuttle/cowl cover and pull the 3 fuses to see if that cures it.
if it does then the fuses will remain out.
never had a car with 'part time' electric heating so i wont miss it.
Alternator has stopped charging Surreyuk European & Diesel Powered 300 Models 26 12-13-2011 12:48 PM
2006 ac l charging port USNEOD General Discussion on Issues / Trouble Shooting 1 07-12-2011 06:53 PM
Battery/charging/infrequent use redhoss General Discussion on Issues / Trouble Shooting 6 04-26-2011 03:07 PM
Dealer charging me an arm and a leg!! mrxlucky1h General Discussion 28 03-30-2011 08:34 AM
Anyone turbo charging there 300? floner Performance General Discussion 3 04-27-2010 12:10 AM
