ABS, ESP/BAS & TCS lights on after battery outage - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 12-01-2012, 01:03 PM   #11 (permalink)
Points: 30,048, Level: 1 Points: 30,048, Level: 1 Points: 30,048, Level: 1
Activity: 29% Activity: 29% Activity: 29%
tim@thecustom300cshop's Avatar
Car: 2006 Chrysler 300c CRD
Member Number: 37143
Originally Posted by Simon@thecustom300cshop View Post
Its about time you looked at the ns door lock mate, it'll make life a lot easier if you could get in the car when all else fails
Did it today after whilst doing the n/s door projector... no good after the event though eh? The metal rod was off/out of a little violet clip, cliped it back in and hay presto now have the door unlocking manually.
As was said if you have a lockout you can't (well we couldn't) hook the bonnet release. The boot release is also obviously out as its electric.
Just hope these bl**dy lights go out though...
Am I right in saying if the lights are on the relevant systems aren't working as they're switched off by the ECU?
www.custom300cshop.co.uk
Tints¦Clear Sidemarkers¦Startech 22" Rims, Front Splitter & Boot Spoiler¦Mopar Ovals & Shields¦Mopar Grille¦Billet Tech Catch Can¦Stormtech Rear Diffuser & Sideskirts¦MyGig Upgrade with Lockpick¦Viezu 305bhp/538lbsft Torque Performance & Blueoptimize Remaps with V-Switch¦Intercooler Upgrade¦Sonar LED Tail Lights¦DRL's¦Front & Rear Cameras¦De badged Boot Lid¦Blue LED Interior Light Conversion¦Mopar Ghost LED Projector Puddle Lights¦
tim@thecustom300cshop is offline
Old 12-01-2012, 03:01 PM   #12 (permalink)
Points: 27,532, Level: 1 Points: 27,532, Level: 1 Points: 27,532, Level: 1
chrisp's Avatar
Car: 2006 Chrysler 300c SRT-8 {SZZ}
Member Number: 20152
They usually go out after a few starts like Paul says. They come on on the SRT8 if you disconnect the battery but always go off after a few miles. You could try "deactivating" (not normal switching off) the ESP take it for a drive then switch the ESP back on. It worked for me on one of my CRDs when they wouldn't go out
MOPAR OR NOCAR 440 Coronet
2006 SRT8 Diablo Predator 93 Octane CAI performance tune
Mopar Cold Air Intake
EBC Yellows
Hurst Shifter
Badlanz Cutouts
chrisp is offline
Old 12-01-2012, 03:54 PM   #13 (permalink)
Thanks chaps... will wait and hopefully it'll decide for itself everything is cool and turn them off... unless it doesn't like it's new Mopar ghost light additions
Old 12-01-2012, 03:57 PM   #14 (permalink)
chrisp's Avatar
Originally Posted by devilmaycare View Post
Does anyone know if the door barrel lock is located on the same side in LHD models? It would make a lot more sense to have it on the driver's side. My car is parked in a carport and there's very little clearance on the passenger side, so I have to be careful to leave enough "squeezing" room for emergency access.
It is located in the "Drivers" door on LHD ie where it is now on ours. Looks like they didn't bother moving it for RHD
chrisp is offline
Old 12-01-2012, 04:56 PM   #15 (permalink)
Major Contributing Member
Points: 7,758, Level: 1 Points: 7,758, Level: 1 Points: 7,758, Level: 1
devilmaycare's Avatar
Member Number: 7282
Just as I suspected. Its a pity they didn't leave the bonnet (hood) release where it was and this might have saved a few $. It seems that RHD versions of LHD cars always seem to be half-baked in this level of detail. My Audi A4 has its windscreen demister airflow optimised for the passenger, rather than the driver. I doubt that LHD versions of cars built in the UK suffer this problem, but perhaps I'm wrong.
devilmaycare is offline
Old 12-02-2012, 04:06 AM   #16 (permalink)
Points: 25,164, Level: 1 Points: 25,164, Level: 1 Points: 25,164, Level: 1
Activity: 47% Activity: 47% Activity: 47%
Member Number: 37145
Depending on what front grill is fitted, you can get a 13mm 1/4 drive socket and extension through and unbolt the bonnet catch from the slam panel. The holes in the Startech grill are to small, when my bonnet release failed I had to play about getting the top pins out the top of the facia with the bonnet/hood down and remove the facia enough to get in to unbolt the bonnet catch.
I shouldn't have that problem with the new grill though lol.
Regards
Simon
Simon@thecustom300cshop is online now
The Following User Says Thank You to Simon@thecustom300cshop For This Useful Post:
devilmaycare (12-02-2012)
Old 12-02-2012, 07:20 AM   #17 (permalink)
Points: 2,709, Level: 1 Points: 2,709, Level: 1 Points: 2,709, Level: 1
Member Number: 22016
The lights should turn off after taking the car for a drive,mine did when I had to replace a abs sensor
UKCRD is online now
Old 12-02-2012, 07:34 AM   #18 (permalink)
Points: 214, Level: 1 Points: 214, Level: 1 Points: 214, Level: 1
Jim Noble's Avatar
Car: 2009 Chrysler 300C CRD Touring
Member Number: 39048
That would have required a new door handle casting - cheapskates.
Jim Noble is offline
Old 12-02-2012, 04:55 PM   #19 (permalink)
Points: 14,418, Level: 1 Points: 14,418, Level: 1 Points: 14,418, Level: 1
Armchair's Avatar
Car: 2009 Chrysler 300c crd SRT Design
Member Number: 28455
If you are relying on using the emergency key to get in with a flat battery this might be worth reading...
Flat battery... What a palaver!
Armchair is offline
Old 12-03-2012, 11:23 AM   #20 (permalink)
Member Number: 7282
Once entry has been gained via the passenger door, can the driver's door be opened from the inside?
Planned Forum Outage - Tuesday, July 14th HEMEEE Chrysler 300C News & Site News 0 07-13-2009 09:16 PM
Power Outlet Outage Hemi-Roid Problems / Dealer Service 5 05-08-2009 09:40 PM
Flat battery now warning lights stuck on? Fadboy European & Diesel Powered 300 Models 7 03-18-2009 10:03 AM
Battery Icon(volt indicator) and lights flicker VPJ Problems / Dealer Service 9 12-06-2004 10:17 PM
