well,if you're ever in my area you're quite welcome and I'll read your car for you and my machine will read each and every one of your ECU's
4300k hid main lights
4300k hid fog lights
No Crisp, well only via the button which doesn't do anything. How do I disable it?
Fire it up then hold the ESP button in for 8/10 seconds ESP Deactivated will pop up on the EVIC then go for a drive and see what happens. It worked on one of my old CRDs you never know. It will turn back on when you turn the key off.
MOPAR OR NOCAR 440 Coronet
2006 SRT8 Diablo Predator 93 Octane CAI performance tune
Mopar Cold Air Intake
EBC Yellows
Hurst Shifter
Badlanz Cutouts
The Following User Says Thank You to chrisp For This Useful Post:
Think you will find it could be the Steering Angle Sensor that requires initialisation (Code C121A).
On pre 2008 models sensor can be reset by:
1. Turn wheel to straight ahead position
2. Start Engine
3. Turn steering wheel 20 deg to the left then 20 deg to the right (Past straihght ahead position)
4. Drive car straight ahead for at least 3 seconds at a speed above 3.7 mph.
5. Turn engine off and remove key.
Alternative is to start engine with sterring wheel pointing straight ahead and turn wheel from lock to lock a couple of times.
On 2008 onwards models steering sensor can only be reset by the dealers magic machine ???
Alternatively, If you ignore the steering angle sensor code it will reset itself after a few trips. (Mine did anyway)
Jack
The Following User Says Thank You to jackwalton For This Useful Post:
2. Start Engine
Jack
Thanks Jack, just tried both a couple of times to no avail unfortunately.. a stubborn one this.
Unfortunately doesn't seem to do anything, no EVIC message or seeming disabling of ESP.
