ABS, ESP/BAS & TCS lights on after battery outage - Page 5 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 12-05-2012, 11:44 AM   #41 (permalink)
Points: 30,201, Level: 1 Points: 30,201, Level: 1 Points: 30,201, Level: 1
tim@thecustom300cshop's Avatar
Car: 2006 Chrysler 300c CRD
Member Number: 37143
Ray, if they plug it in and read the code and suppose they delete it will it reappear since it'll sense the steering angle sensor hasn't been reset or will the action of deleting the code reset it?
www.custom300cshop.co.uk
Tints¦Clear Sidemarkers¦Startech 22" Rims, Front Splitter & Boot Spoiler¦Mopar Ovals & Shields¦Mopar Grille¦Billet Tech Catch Can¦Stormtech Rear Diffuser & Sideskirts¦MyGig Upgrade with Lockpick¦Viezu 305bhp/538lbsft Torque Performance & Blueoptimize Remaps with V-Switch¦Intercooler Upgrade¦Sonar LED Tail Lights¦DRL's¦Front & Rear Cameras¦De badged Boot Lid¦Blue LED Interior Light Conversion¦Mopar Ghost LED Projector Puddle Lights¦
tim@thecustom300cshop is offline
Old 12-05-2012, 05:01 PM   #42 (permalink)
Major Contributing Member
Points: 14,657, Level: 1 Points: 14,657, Level: 1 Points: 14,657, Level: 1
Armchair's Avatar
Car: 2009 Chrysler 300c crd SRT Design
Member Number: 28455
Originally Posted by jackwalton View Post
On 2008 onwards models steering sensor can only be reset by the dealers magic machine ???
Alternatively, If you ignore the steering angle sensor code it will reset itself after a few trips. (Mine did anyway)
Jack
A similar experience here.
I have had the same problem twice. The first time was after I disconnected the battery to fit a towbar wiring kit. The battery was disonnected for two full days. I booked it in to a dealer for a look see. However, I didn't actually go because the fault cleared itself on the same day. When the car was serviced a couple of months later I asked them to check it. They told me that they had found and cleared a stored historical code for a faulty steering sensor but that it wasn't a problem as the sensor had reset itself.
The second time it happened was after I had a flat (4 volts IIRC) battery and swapped it for a new one. Again the ESC warning lamp came on but cleared itself within a few miles. No problems since.
Armchair is offline
Old 12-06-2012, 03:33 AM   #43 (permalink)
Points: 35,952, Level: 1 Points: 35,952, Level: 1 Points: 35,952, Level: 1
Activity: 55% Activity: 55% Activity: 55%
UK CHRYSLER 300C's Avatar
Member Number: 12398
No,it has to be reset,on my machine theres a pic of a steering wheel and degrees either side and you turn the wheel until zero shows then I press the activation button and do exactly what the screen tells me to do,not done a C yet but VW's you have to drive in a straight line while activating my machine for at least 10 metres
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
Old 12-06-2012, 06:38 AM   #44 (permalink)
ok so my local garage's Snap On diagnostic tool doesn't have Chrysler on it. Last stitch attempt today by disconnecting the battery and removing Fuse 11 for a few hours otherwsie maybe a trip to the Stealer... unlesss... how many hundreds of Miles are you away Ray?
Old 12-06-2012, 08:37 AM   #45 (permalink)
depends where you are Tim.....I'm at J14 M6
Old 12-06-2012, 12:16 PM   #46 (permalink)
150 miles.. doh.
Stealer can't put it on the Starscan till next Friday and wonder if they'll just point at a sensor (and £££'s). RAC guy reckons it could be a software issue, i.e. after battery outage the PCM (or what ever it is) has had its software scrambled, either that or the steering angle sensor has popped?
Old 12-06-2012, 12:24 PM   #47 (permalink)
Points: 17,677, Level: 1 Points: 17,677, Level: 1 Points: 17,677, Level: 1
Member Number: 18868
Is it the case that it's only the diesel cars have had this problem.
I have disconnected the battery on my car a number of times and never had a problem other than the window switch reset. My radio preset stations don't even get lost, there must be some sort of backup battery / capacitor in the radio.
ivanford is online now
Old 12-06-2012, 12:35 PM   #48 (permalink)
Points: 7,787, Level: 1 Points: 7,787, Level: 1 Points: 7,787, Level: 1
devilmaycare's Avatar
Member Number: 7282
It might be that data is stored in non-volatile flash memory; eg as used in 'phones and, of course, the ECU.
devilmaycare is offline
Old 12-06-2012, 01:08 PM   #49 (permalink)
Points: 55,052, Level: 1 Points: 55,052, Level: 1 Points: 55,052, Level: 1
Activity: 29% Activity: 29% Activity: 29%
Car: Chrysler 300c 2009 CRD
Member Number: 37144
150 miles.. doh.
8-9 gallon of fuel.
Is your local stealer good with you / fair? and maybe a wasted trip.
As a trip to stafford wouldnt be
Old 12-06-2012, 02:18 PM   #50 (permalink)
Hmm.. do I trust them... nop. Affraid they'll just give me conflab about a sensor and as they're unlikely to allow me to witness the scan I'll only have there word for it.
Worried really as obviously if the warning lights are on I have no ABS, Traction or Stability on and with the colder weather....
Planned Forum Outage - Tuesday, July 14th HEMEEE Chrysler 300C News & Site News 0 07-13-2009 09:16 PM
Power Outlet Outage Hemi-Roid Problems / Dealer Service 5 05-08-2009 09:40 PM
Flat battery now warning lights stuck on? Fadboy European & Diesel Powered 300 Models 7 03-18-2009 10:03 AM
Battery Icon(volt indicator) and lights flicker VPJ Problems / Dealer Service 9 12-06-2004 10:17 PM
