ABS, ESP/BAS & TCS lights on after battery outage - Page 7 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 12-08-2012, 02:41 PM   #61 (permalink)
Points: 28,936, Level: 1 Points: 28,936, Level: 1 Points: 28,936, Level: 1
chrisp's Avatar
Car: 2006 Chrysler 300c SRT-8 {SZZ}
Member Number: 20152
Originally Posted by tim@thecustom300cshop View Post
Ta Paul, can't say I've ever really looked to see if they work anyway.
Changed the motor on mine a bit back it had blown the fuse and was seized. They should work first press of the washer (with the headlights on) and every fifth press after.
MOPAR OR NOCAR 440 Coronet
2006 SRT8 Diablo Predator 93 Octane CAI performance tune
Mopar Cold Air Intake
EBC Yellows
Hurst Shifter
Badlanz Cutouts
chrisp is offline
Old 12-08-2012, 02:59 PM   #62 (permalink)
Points: 36,618, Level: 1 Points: 36,618, Level: 1 Points: 36,618, Level: 1
UK CHRYSLER 300C's Avatar
Member Number: 12398
Tim,forgot to ask,what machine did the guy have to diagnose our car?... same as mine or not?
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
Old 12-08-2012, 05:02 PM   #63 (permalink)
Points: 31,480, Level: 1 Points: 31,480, Level: 1 Points: 31,480, Level: 1
tim@thecustom300cshop's Avatar
Car: 2006 Chrysler 300c CRD
Member Number: 37143
Can't remember Ray, I was too busy F'ing and Blind'ing that I needed to go to the Stealer and cursing myself for playing with lights.. which is what caused the low battery power in the first place!
It was a portable jobbie and I did see the name but can't remember. If you suggest some I'll probably be able to tell you. If not I'll call them on Monday and find out.
www.custom300cshop.co.uk
Tints¦Clear Sidemarkers¦Startech 22" Rims, Front Splitter & Boot Spoiler¦Mopar Ovals & Shields¦Mopar Grille¦BT Catch Can¦Stormtech Rear Diffuser & Sideskirts¦MyGig Upgrade with Lockpick¦Viezu 305bhp/538lbsft Performance & Blueoptimize Remaps¦Intercooler Upgrade¦LED Tail Lights¦DRL's¦Front & Rear Cameras¦De badged Boot Lid¦Blue LED Interior Light Conversion¦Mopar Ghost LED Projector Puddle Lights¦Lowered by 30mm¦DPF Removed¦EGR Deleted
tim@thecustom300cshop is offline
Old 12-09-2012, 03:22 AM   #64 (permalink)
Did it look like this
ABS, ESP/BAS & TCS lights on after battery outage-image.jpg
Old 12-09-2012, 05:54 AM   #65 (permalink)
Nop. Will find out tomorrow
Sent from my GT-S5830 using AutoGuide.Com Free
Old 12-09-2012, 02:10 PM   #66 (permalink)
Well that one in the pic is mine and its vehicle specific and as our phone conversation it does sh1t loads on the C
Old 12-10-2012, 05:20 AM   #67 (permalink)
PM sent Tim.....
Old 12-10-2012, 03:35 PM   #68 (permalink)
Points: 3,061, Level: 1 Points: 3,061, Level: 1 Points: 3,061, Level: 1
Member Number: 41160
Originally Posted by Pappajohn View Post
Dont know if it will get seen in this thread but nowt to lose.
same problem with warning lights myself today.
been in for a tyre change and removal of the remaining two TPS sensors.
couple of minutes up the road and got a boing !
ABS, BAS, ESP all came on together.
looking at earlier posts on this thread is appears the warning lights will turn themselves off after a few starts.....does it happen or will they need resetting via OBD reader and see if they reappear ?
just realised OBD reader wont sort this one out.
Sorted.
my bro put his code reader on it and it came back with three codes.
main one was C102B....O/S rear ABS sensor electrical failure.....no signal.
still needs replacing so the lights are still on.
second was C2100... 'low battery volts' or something like that (electric cabin heater was still active which i still blame for volt drop)
third was code C121A....'steering angle sensor not initialised'
did the 'centre, left, right, left, centre' calibration, which I also did the other day when the lights came on so suspect it was just a stored code and it didn't reappear after being cleared.
no other codes found.
Pappajohn is offline
Old 12-12-2012, 04:32 PM   #69 (permalink)
Resolution to code U140E - implausible vehicle configuration
Visited Dealer today to solve my implausible vehicle configuration code problem. From what I gathered it was plausible that the low voltage and subsequent power up caused a probable software corruption. It was also suggested it would be implausible that starting whilst jacked up caused the issue, as was it improbable that the RAC tech did anything to a component underneath. I did ask considering I had the issue how an obviously plausible problem could have arisen if Chrysler consider it implausible and didn't really get an answer but thinking about it, software is still basically binary so the car has to either decide the issue is as in this case as 0 implausible or a 1 plausible, so it looks like my car confused itself by thinking something plausible was implausible....
Credit where credit's due though... dealer solved quickly and I was pleasantly surprised by the bill, not so when I went to pay for it though when I realised I'd left my card in a poxy shop machine earlier in the day.... how implausible was that I thought!
Old 12-12-2012, 04:46 PM   #70 (permalink)
Points: 1,355, Level: 1 Points: 1,355, Level: 1 Points: 1,355, Level: 1
royliz's Avatar
Car: 2010 (EYO) chrysler 300c crd touring
Member Number: 35705
sound feesable and highly probable i know iu cant spell lol
Roy
royliz is offline
Planned Forum Outage - Tuesday, July 14th HEMEEE Chrysler 300C News & Site News 0 07-13-2009 09:16 PM
Power Outlet Outage Hemi-Roid Problems / Dealer Service 5 05-08-2009 09:40 PM
Flat battery now warning lights stuck on? Fadboy European & Diesel Powered 300 Models 7 03-18-2009 10:03 AM
Battery Icon(volt indicator) and lights flicker VPJ Problems / Dealer Service 9 12-06-2004 10:17 PM
