I have a 3.5 V6 petrol in my 300c which is the same a Charger
I've come across this on a charger forum - but not sure if will work in a diesel....
Do you know if it's throwing any DTC codes???? Here's how to access it:
"From the Top 150 + Tips & Tricks"
1. Get in the car, close the door.
Perform steps 2-6 fairly quickly (less than 3 sec's total time).
(The key should not return to the OFF position through this next sequence!)
2. Turn key to 'ON' position
3. then back to 'ACC'
4. then to 'ON'
5. then back to 'ACC'
6. then to 'ON'
If there are any stored codes, they will appear immediately, in place of the odometer.
I'm afraid that doesn't work on CRuDs, it only works on petrols... not sure why though?
4300k hid main lights
4300k hid fog lights
Right, diagnostic tool arrived, where does it plug in ?
I will do it at lunch time and see what codes it has for me. Do I reset then or wait and see what the codes say ??
Its under the dash,drivers side just about in line with the brake pedal,plug it and read the codes first,write them down and post them on here then you can wipe them
The Following User Says Thank You to UK CHRYSLER 300C For This Useful Post:
