Tyre pressure monitoring system fault - Page 3 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 12-30-2012, 09:52 AM   #21 (permalink)
Points: 35,701, Level: 1 Points: 35,701, Level: 1 Points: 35,701, Level: 1
Activity: 40% Activity: 40% Activity: 40%
UK CHRYSLER 300C's Avatar
Member Number: 12398
If skreem fails then the immobiliser cuts in and you ain't going anywhere
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
Old 12-30-2012, 12:16 PM   #22 (permalink)
Points: 383, Level: 1 Points: 383, Level: 1 Points: 383, Level: 1
Activity: 26% Activity: 26% Activity: 26%
Car: 2006 Chrysler 300c Diesel
Member Number: 42121
Originally Posted by devilmaycare View Post
It looks as if the SKREEM is failing to deduce the position of the fourth sensor in the wheel arch without a transponder. It does seem odd though, that such a fault could have been triggered by wheel replacement. Have you checked for fault codes? These two could be relevant:
C1509–RIGHT REAR TIRE PRESSURE
TRANSPONDER MODULE
PERFORMANCE . . . . . . . . . . . . . . . . . . . . . .22-44
C150C–RIGHT REAR TIRE PRESSURE
TRANSPONDER MODULE VOLTAGE
HIGH . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .22-55
Hi ive never had any fault codes read on the car at all would my mates snap on solus be able to read that ???
neo2 is offline
Old 12-30-2012, 12:19 PM   #23 (permalink)
So do you think its looking like the Skreem thing then ???
If it is im getting shot of the car as im not going down the same route as my last range rover cant be doing with another pile of shite...
I suppose the skreem thing is a fortune and coded to ecu etc etc and a specailist job as well etc etc
neo2 is offline
Old 12-30-2012, 01:29 PM   #24 (permalink)
Points: 27,368, Level: 1 Points: 27,368, Level: 1 Points: 27,368, Level: 1
badgx's Avatar
Member Number: 32952
Neo unless you know someone with a code reader, I would think the cost of a secondhand transponder from the breakers would weigh far less than to get a code read. Also the basic code readers may not all have the same specific capacity as dealership equipment to give you a pin point code.
I would contact the a decent breakers like Charltons and get a UK spec 2nd hand transponder for the rear right wheel arch and see how you get on.
If the problem persist after changing the transponder, then take it straight to the dealers or an independent garage with appropriate equipment for further investigation. The dealers use Starscan to interrogate the system and charge something like ~ £90 per hour for a diagnostic, so it can be expensive.
Good luck, hope it gets sorted
badgx is offline
Old 12-30-2012, 02:28 PM   #25 (permalink)
No,I don't think that your skreem is going down
Old 12-30-2012, 02:29 PM   #26 (permalink)
Badgx = sorry if this is a thick question you say its the transponder in the right rear wheel arch liner i need (yet its the left rear wheel showing 0.0 bar) is there only one rear transponder ?? the reason i say this is the right rear is working ok thats all.. what do they look like ?? any idea on the price of a new one ??
Neo alias Rob
neo2 is offline
Old 12-30-2012, 02:30 PM   #27 (permalink)
No,your mates solus won't be able to read that,solus is ok on some cars but not ours,skreem can only be read by Starscan
Old 12-30-2012, 02:32 PM   #28 (permalink)
Thank god for that lol
Ive just had the worst expierience ever with what looked like a lush range rover £2000 later in electrical issues i sold the piece of shit and bought the 300C at least its doing 34mpg urban compared to range rover 16mpg...
neo2 is offline
Old 12-30-2012, 02:41 PM   #29 (permalink)
Tipical it would be free lol
neo2 is offline
Old 12-30-2012, 02:53 PM   #30 (permalink)
What model Rangey was it?
Tyre Pressure fault r11gjh European & Diesel Powered 300 Models 2 05-18-2009 04:47 AM
Is Tire Pressure Monitoring System Accurate? srt8man General Discussion 24 11-12-2008 06:48 PM
TIRE PRESSURE MONITORING SYSTEM Adapters for 22s td300c Custom Wheels & Tires 5 06-19-2007 03:43 PM
Tyre Pressure monitoring in EVIC Rgr European & Diesel Powered 300 Models 5 05-23-2007 03:20 AM
Tire Pressure Monitoring System memobug Custom Wheels & Tires 6 09-16-2005 07:09 PM
