Tyre pressure monitoring system fault - Page 4 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 12-30-2012, 03:09 PM   #31 (permalink)
Points: 27,379, Level: 1 Points: 27,379, Level: 1 Points: 27,379, Level: 1
badgx's Avatar
Member Number: 32952
Originally Posted by neo2 View Post
Badgx = sorry if this is a thick question you say its the transponder in the right rear wheel arch liner i need (yet its the left rear wheel showing 0.0 bar) is there only one rear transponder ?? the reason i say this is the right rear is working ok thats all.. what do they look like ?? any idea on the price of a new one ??
Neo alias Rob
No Neo, its nots a thick question, we try and help here so your welcome to ask away AND I want you to do one more thing before you get that transponder!
Move the rear right wheel to the front aswell, because according to your post 18 you only moved rear left only and didn't following the suggestion I gave at post 17, that is to move both rear wheels to the front
Remember the TMPS works on a process of elimination.
After that, at DIY level all you can do is to replace the transponder. Brand new ones for the front end cost about £44 each from the dealers. So I would think you may be able to get secondhand ones cheaply and there is only 1 located to the rear right side wheel arch that does the job for the rear.
If it works you can buy us all a drink
badgx is offline
Old 12-30-2012, 05:07 PM   #32 (permalink)
Points: 383, Level: 1 Points: 383, Level: 1 Points: 383, Level: 1
Activity: 26% Activity: 26% Activity: 26%
Car: 2006 Chrysler 300c Diesel
Member Number: 42121
ok no bother will try and swop the right hand rear to the front and vice versa too see if that makes any differences first i will try anything its annoying me thats all on the dash all the time....
neo2 is offline
Old 12-30-2012, 05:11 PM   #33 (permalink)
Originally Posted by badgx View Post
Rob, have you tried rotating by moving the rear wheels to the front axle and the front wheels to the rear axle as suggested to see if it made any difference? You know 100% the front sensors are working, do a swap test to see, you can put them back afterwards
i must of miss read it i just assummed it was just the wheel in question lol my mistake....
neo2 is offline
Old 12-30-2012, 06:04 PM   #34 (permalink)
Points: 27,624, Level: 1 Points: 27,624, Level: 1 Points: 27,624, Level: 1
chrisp's Avatar
Car: 2006 Chrysler 300c SRT-8 {SZZ}
Member Number: 20152
As above as Badgx suggests. But also check you have the right part no on that new rubber valve
MOPAR OR NOCAR 440 Coronet
2006 SRT8 Diablo Predator 93 Octane CAI performance tune
Mopar Cold Air Intake
EBC Yellows
Hurst Shifter
Badlanz Cutouts
chrisp is online now
Old 12-31-2012, 03:00 AM   #35 (permalink)
Points: 35,701, Level: 1 Points: 35,701, Level: 1 Points: 35,701, Level: 1
Activity: 40% Activity: 40% Activity: 40%
UK CHRYSLER 300C's Avatar
Member Number: 12398
Surely if there's only one transponder for the rear sharing the the two rear tyres and only one tyre pressure is reading then the sender must be at fault otherwise both rears would be reading zero.....
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
Old 12-31-2012, 04:34 AM   #36 (permalink)
Major Contributing Member
Points: 7,758, Level: 1 Points: 7,758, Level: 1 Points: 7,758, Level: 1
devilmaycare's Avatar
Member Number: 7282
swopped wheel off nearside front as i know it worked to nearside rear and vise versa expecting the 0.0bar reading to go to the front, but it never nearside rear wheel still showing 0.0bar
Surely this points to a problem with the rear transponder? This transponder is able to pick up a signal from the nearest wheel, but not from the furthest one. The suspect wheel does work in a different position, so its sensor must be OK.
devilmaycare is offline
Old 12-31-2012, 06:54 AM   #37 (permalink)
badgx's Avatar
Neo only moved the rear left wheel with the new sensor to the front axle and it was working at the front. I'm now waiting for Neo to move the rear right wheel to the front to rule out the odd before tackling the rear transponder.
My thinking is you need all 4 sensors in good working order including the ones on the rear on both sides for the process of elimination to work correctly.
The EVIC did display a reading to the rear. We assume this reading was for the rear right according to EVIC display.
Lets see to be sure before tackling the transponder
badgx is offline
Old 12-31-2012, 01:13 PM   #38 (permalink)
I have a right rear sensor missing completely on mine and my left sensor still shows a pressure
Old 01-02-2013, 06:32 AM   #39 (permalink)
badgx's Avatar
Any updates Neo, I assume everything is OK? Would be grateful if you could confirm for info as members will benefit too if we were ever in the same situation as you
badgx is offline
Old 01-02-2013, 11:36 AM   #40 (permalink)
Hi Badgx sorry for the slow reply i managed to change the remaining wheel front to rear so as it stands now both the rear wheels are on the front and both fronts on the rear..
And it is still the same ive done 70/80 miles and still have the Nearside rear showing 0.0 bar..
so in all its had...
1, new nearside rear sensor (no change)
2, Wheel deflated and blown up while running (no change)
3, Nearside rear wheel moved to from and front to rear (no change)
4, Off side rear wheel moved from rear to front and front to rear (no change)
So as it stands now no change at all from the original fault...
neo2 is offline
Tyre Pressure fault r11gjh European & Diesel Powered 300 Models 2 05-18-2009 04:47 AM
Is Tire Pressure Monitoring System Accurate? srt8man General Discussion 24 11-12-2008 06:48 PM
TIRE PRESSURE MONITORING SYSTEM Adapters for 22s td300c Custom Wheels & Tires 5 06-19-2007 03:43 PM
Tyre Pressure monitoring in EVIC Rgr European & Diesel Powered 300 Models 5 05-23-2007 03:20 AM
Tire Pressure Monitoring System memobug Custom Wheels & Tires 6 09-16-2005 07:09 PM
