When installing EBC pads, this tip will help stop the squeal if done with care
(a) Apply copper grease to the back of brake pad,
(b) but also most importantly apply to the top and bottom ends of the pad, see photo for illustration.
(c) Blast the callipers and disc with brake cleaning fluid before installation.
(d) After a weeks worth of driving, give another blast of spray with brake cleaning fluid to remove any loose dust. Dust will look pink in colour, its the residue or remains of the course material applied during manufacturing process to the contact surface of the pad designed to aid with initial bedding process. EBC is notoriously known for that, so blast away as much of that dust as possible and give the wheels a wash too. You won't need to do (d), to stock pads though
