iPod connector? - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 01-13-2013, 10:09 AM   #1 (permalink)
Points: 2,043, Level: 1 Points: 2,043, Level: 1 Points: 2,043, Level: 1
esgyrndafydd's Avatar
Car: 2006 Chrysler 300c CRD Touring
Member Number: 39985
iPod connector?
Is there a simple way of doing this?
AIUI, most wiring kits are simply a male/female interupt to the existing wiring so you unplug the present connectors, plug in the kit and then plug the existing wiring back into that. Any accessories then plug into the wiring kit.
So far so good except for cost, most seem to be fairly expensive, all [?] I want is something simple that will allow me to use the aux input of the REJ for my iPod [and if it can charge the thing at the same time so much the better]
Is this sort of thing available without too much cost or grief?
David Kennedy
esgyrndafydd is offline
Old 01-13-2013, 11:20 AM   #2 (permalink)
Points: 2,974, Level: 1 Points: 2,974, Level: 1 Points: 2,974, Level: 1
Car: 06 Chrysler 300C
Member Number: 4395
I paid about 80$ on this on amazon for my 1g with the REC.
jaminmon is online now
Old 01-13-2013, 12:34 PM   #3 (permalink)
Points: 56,859, Level: 1 Points: 56,859, Level: 1 Points: 56,859, Level: 1
Activity: 74% Activity: 74% Activity: 74%
Car: Chrysler 300c 2009 CRD
Member Number: 37144
if you would be happy with a 3.5mm headphone socket as an input, there a free mod that you can do. ill try and find the link if needed
www.custom300cshop.co.uk
Old 01-13-2013, 01:04 PM   #4 (permalink)
As a last resort then yes and thanks for the offer. I just wanted to explore the possibility of an actual ipod connector which would charge the thing as well to try to avoid my present situation where the car is festooned with leads...
Old 01-13-2013, 01:06 PM   #5 (permalink)
What did you buy, will it work with an REJ radio and how did you do it?
Old 01-13-2013, 02:29 PM   #6 (permalink)
Points: 30,136, Level: 1 Points: 30,136, Level: 1 Points: 30,136, Level: 1
badgx's Avatar
Member Number: 32952
This is an inline FM ipod modulator kit, which will work for ipod. It has 3 frequencies, I go with 88.3 FM if memory serves me correctly. Then add a small switch, when you want to listen to ipod as it block other radio stations and all you do is tune to 88.3 FM and it plays your ipod at the selected frequency.
I added the switch and hide it between the drivers seat and plastic console. When you want to listen to the radio, you simply flick back the switch
This is the kit, but I have a different one though for my rec unit. Also the antenna sockets are different on ours and the adapter alone can be expensive but this kit I think by the looks of it comes with the correct adapters, but please do enquire to make sure that it will plug into the head unit
CHRYSLER 300c Grand Tourer Car iPod iPhone FM Modulator Adaptor DS-FM-CHRYSLER | eBay
badgx is offline
The Following User Says Thank You to badgx For This Useful Post:
esgyrndafydd (01-13-2013)
Old 01-13-2013, 10:16 PM   #7 (permalink)
Member Number: 4395
Hey there,
I bought this from Amazon:
This might also work:
Don't be fooled - it is not USA specific...
Both of these require you to pull the radio out (most of the way at least) in order to connect everything up. The good thing is that it is not hard at all to do. I did it while my wife was shopping at the grocery store and finished it before she was done. Ha! Just a quick suggestion, if the one I bought also works for the REJ, the unit also has an aux-in RCA jack that I connected a Bluetooth receiver to (I needed a female 3.5 mm stereo to male RCA adapter cable in order to do it) so that I could stream music to my unit as well as make Bluetooth calls that sound better than the UConnect system... Just a thought. It solved the problem that I had when I got the iphone5 with the new connector... Good luck. And let me know if you want more on my install.
Ben
Old 01-13-2013, 10:20 PM   #8 (permalink)
Thanks, I'll check it out.
Old 01-13-2013, 10:29 PM   #9 (permalink)
And, while were here, what is it with people in the USA and their postage/shipping charges? Are they delivering them in person? Is it a gold plated box?
Old 01-13-2013, 10:34 PM   #10 (permalink)
Member Number: 4395
Ha! The former I believe
iPhone via the iPod connector? (Moved) faelchu11 Car Audio/Alarms/UConnect/Navigation 4 12-11-2008 03:36 PM
Is there plans for a Steering Wheel controlled Ipod connector? Darrenph1 Car Audio/Alarms/UConnect/Navigation 0 06-29-2006 05:42 PM
New iPod connector Ruppstar Parts Buy/Sell Forum 1 11-10-2004 02:18 PM
iPod connector... D300C Appearance General Discussion 1 10-18-2004 05:17 AM
