Tyre pressure sensors. Ebay ? - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 01-16-2013, 03:49 PM   #11 (permalink)
Major Contributing Member
Points: 7,880, Level: 1 Points: 7,880, Level: 1 Points: 7,880, Level: 1
devilmaycare's Avatar
Member Number: 7282
Originally Posted by Z06-Z06 View Post
My only issue was / is, no leak found when in the water bath. (the wheel, not me lol)
Did you fit the rubber type ? If so, main dealer ?
Cheers,
Dale.
Water alone may not reveal a very slow leak. With a soapy solution you will spot a single bubble forming and increasing in size over a few minutes. I've seen tyre fitters using this trick with good effect. My replacement sensor came from the main dealer and was the metal type.
devilmaycare is offline
Old 01-16-2013, 04:12 PM   #12 (permalink)
Points: 4,542, Level: 1 Points: 4,542, Level: 1 Points: 4,542, Level: 1
Car: 2009 Chrysler 300c
Member Number: 34223
Thanks for your replies.
I don't have an issue with my sensor as such. What I do have is a VERY slow leak. Approx 0.5 bar over a 2-3 day period. Have put the wheel in a water bath, but other than coming out cleaner, no signs of any leak.
It's just a PITA to keep pumping it up. So my only guess is than the sensor stem / body has a very slight leak ?
Any ideas. ?
Dale.
Exactamundo the same problem on my rear O/S
I took it to lanoitaN seryT and the nice chap said it was leaking
at the sensor stem, he removed the tyre to investigate, the rubber seal was shot and he couldn't remove the securing nut to remove it but didn't want to force it lest it break.
He advised getting a new sensor and refitted the tyre [ BTW he didn't charge me a penny, well done NT ].
Up shot is, since its removal the said tyre has held its pressure, so I don't know what the guy did, but he fixed it anyway.
jeyaar789 is offline
Old 01-16-2013, 04:16 PM   #13 (permalink)
Points: 30,028, Level: 1 Points: 30,028, Level: 1 Points: 30,028, Level: 1
badgx's Avatar
Member Number: 32952
Seals
badgx is offline
Old 01-17-2013, 02:05 AM   #14 (permalink)
Points: 25,777, Level: 1 Points: 25,777, Level: 1 Points: 25,777, Level: 1
Member Number: 37145
Thats pretty much what I always do. I simply put some very dilute washing up liquid in a trigger spray and spray a mist of it all over the tyre, rim and valve. You soon find the leak
Regards
Simon
www.custom300cshop.co.uk
Simon@thecustom300cshop is online now
Old 01-20-2013, 12:38 PM   #15 (permalink)
Points: 3,061, Level: 1 Points: 3,061, Level: 1 Points: 3,061, Level: 1
Member Number: 41160
If you want to look proper posh then Screwfix do a leak detection spray for £3.60
Leak Detection Spray 400ml | Screwfix.com
only does the same as soapy water though.
Pappajohn is offline
Tyre Pressure Sensors? Liffeywater European & Diesel Powered 300 Models 13 06-24-2011 04:34 PM
Tyre Pressure Sensors Michaelr Australia Forum General Discussion 20 03-27-2011 11:08 PM
Tyre pressure sensors paul@thecustom300cshop European & Diesel Powered 300 Models 6 05-05-2010 01:50 AM
Tyre pressure sensors huskydog Australia Forum General Discussion 4 01-05-2010 03:37 AM
F/S - Tyre Pressure Sensors - x3 Jected Parts Buy/Sell Forum 10 09-05-2007 08:10 PM
