Air ! - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 02-04-2013, 04:05 AM   #1 (permalink)
Points: 26,392, Level: 1 Points: 26,392, Level: 1 Points: 26,392, Level: 1
padpadpadpad's Avatar
Car: 2007 Chrysler 300c CRD 3.0 Lux
Member Number: 20662
Air !
Is there a modified air filter for the 300c CRD yet ? - got a spider and have problems with the engine pulling back under hard acceleration (unless I lower the spider settings to next to useless). Wondering if allowing more air in will help.
padpadpadpad is offline
Old 02-04-2013, 04:49 AM   #2 (permalink)
Does this fir the 300c CRD properly - anyone got one ? > K&N AIR FILTER FOR CHRYSLER 300C 3.0 V6 DIESEL 05-10 | eBay
Old 02-04-2013, 05:29 AM   #3 (permalink)
Points: 3,542, Level: 1 Points: 3,542, Level: 1 Points: 3,542, Level: 1
dm575's Avatar
Car: 2007 Chrysler 300C Touring CRD
Member Number: 21528
Yep, fits fine. No difference in sound or power though
dm575 is online now
Old 02-04-2013, 06:05 AM   #4 (permalink)
Points: 55,000, Level: 1 Points: 55,000, Level: 1 Points: 55,000, Level: 1
Activity: 28% Activity: 28% Activity: 28%
Car: Chrysler 300c 2009 CRD
Member Number: 37144
You could try removing the other part of the airbox ( cant remember the name of it) as that will restrict it a bit, its behind the nearside wheel arch linning
photo number 4 here- Big Intercooler + HKS panel filter + remap = 297HP
www.custom300cshop.co.uk
Old 02-04-2013, 06:28 AM   #5 (permalink)
Really so no benefit ?, am I just as well leaving the stock in and not wating my money then ?
Old 02-04-2013, 07:52 AM   #6 (permalink)
Points: 25,245, Level: 1 Points: 25,245, Level: 1 Points: 25,245, Level: 1
Member Number: 37145
I don't think air is your problem. You could try removing the spider's wiring from the conduit and checking the crimped joints that are hidden inside.
Regards
Simon
Old 02-04-2013, 08:40 AM   #7 (permalink)
Points: 6,952, Level: 1 Points: 6,952, Level: 1 Points: 6,952, Level: 1
Car: 2006 chrysler 300c crd
Member Number: 41011
i have a pipercross panel and ai have takent the air silencer out and fitted a cold air feed to the grill next to the fog light that made a big difference
alex uk is online now
The Following User Says Thank You to alex uk For This Useful Post:
dm575 (02-04-2013)
Old 02-04-2013, 12:07 PM   #8 (permalink)
HAd it out a few times - seems that if I set it to notice a diffence then when I floor it it has a "hissy fit" (juddering / pulling back)... but if I accelerate slowly first then floor it it's fine ?!. Assumed it was the air / fuel raio or something. Maybe I need to bin the SPIDER.
Why do K&N make a filter if it does not increase airflow !?
Old 02-04-2013, 01:53 PM   #9 (permalink)
my k&n was good it did make a difference but pipercorss is better also that air silencer under the air box behind the bumper does restrict air
Old 02-04-2013, 03:42 PM   #10 (permalink)
The air filter will not make any difference to your current problem, unless your current air filter is blocked, by all means change it if you want it to make a noise but dont expect it to cure your problem unless yours is blocked with sh1te.
You will have issues if the spider is turned up to high or has a problem with it. Does your spider have just one row of jumpers or two on it? My one only had one row and was fine when it was set two jumpers down from full power, any higher and it didn't like it.
