Oil pressure - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 02-17-2013, 03:43 AM   #11 (permalink)
Points: 11,361, Level: 1 Points: 11,361, Level: 1 Points: 11,361, Level: 1
Member Number: 25742
The symptoms of my alternator cable breaking were taking longer to start, lights began flickering a lot and heater/dashboard lights would get stronger when I accelerated/revved the engine. Also check your volt measurements on your evic menu, anything below 14 there is something wrong.
J_LI is offline
Old 02-17-2013, 06:06 AM   #12 (permalink)
Major Contributing Member
Points: 7,784, Level: 1 Points: 7,784, Level: 1 Points: 7,784, Level: 1
devilmaycare's Avatar
Member Number: 7282
Originally Posted by jackwalton View Post
Definitley does not measure oil pressure on the 300C which is ridiculous.
The reading is fiddled on the EVIC to a fixed pressure. If there was an oil pressure sender the reading would change on the EVIC but it never changes. Its a fixed reading of 115 under all engine operating conditions.
The Oil LEVEL sender brings up the Oil Warning Light.
Jack
The workshop manual is extremely misleading, in that it provides details for the operation, removal and replacement of a sensor which doesn't exist. A similar situation arises for the fuel filter, which is supposed to have a Water-in-Fuel (WIF) sensor and a water drain valve, neither of which exist. It must be the case that there are different versions of the OM642 engine, which the LX manual doesn't acknowledge.
devilmaycare is offline
Old 02-17-2013, 07:14 AM   #13 (permalink)
Member Number: 7282
Oil Filler Cap position
I've just checked my oil filler cap and I have tried it in both positions. The fittings are completely symmetrical, so I can't see why the orientation should have any effect. There are no painted lines visible. I've never come across a filler cap on any car, that hasn't been symmetrical; it must take a bit of effort to design one like that.
Old 02-17-2013, 07:22 AM   #14 (permalink)
Points: 35,919, Level: 1 Points: 35,919, Level: 1 Points: 35,919, Level: 1
Activity: 54% Activity: 54% Activity: 54%
UK CHRYSLER 300C's Avatar
Member Number: 12398
Jack
Must be different on the Hemi's,I've just gone to mine and started it up and the oil pressure was 60psi and when I picked the revs up the pressure went up to 65 so mine isn't a fixed reading,I haven't looked for a pressure switch on mine....oh and I think you'll find that yours isn't an oil level indicator,it's a low pressure warning switch
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
Old 02-17-2013, 07:37 AM   #15 (permalink)
Points: 5,328, Level: 1 Points: 5,328, Level: 1 Points: 5,328, Level: 1
Member Number: 28359
Ray,
I'm sure you will find there is no Oil Pressure switch or Oil Pressure Transducer on the diesels.
There is definitley an Oil Level Switch though.
Jack
jackwalton is online now
Old 02-17-2013, 08:06 AM   #16 (permalink)
Where is this oil level indicator sensor then?, they're normally bolted to the sump and I'm sure the CRuD hasnt got one,I don't know any car that doesn't have an oil pressure switch,cars with oil level sensor have a light for pressure and some other means to tell you that it's low on oil. What you have is an oil pressure switch and if the little red oil light comes on then you're in trouble.
It's definately an oil pressure switch and my oil pressure gauge on the EVIC it definately is not a fixed reading of 115 and 115 is very high oil pressure at any revs for a stock engine
Old 02-17-2013, 08:10 AM   #17 (permalink)
Points: 6,995, Level: 1 Points: 6,995, Level: 1 Points: 6,995, Level: 1
Activity: 47% Activity: 47% Activity: 47%
Car: 2006 chrysler 300c crd
Member Number: 41011
evic says 114 on the oil pressure and does not move and its been the same since i have had it it hasn't changed after the map oil catch can and oter mods its had
alex uk is online now
Old 02-17-2013, 08:12 AM   #18 (permalink)
Like I said....must be different for us Hemi boys as mine reads and fluctuates on revs.......maybe cos we've got proper engines.....lol
Old 02-17-2013, 08:18 AM   #19 (permalink)
may have a proper engine but at least it dont cost me 20 quid to do 10 miles hahaha
Old 02-17-2013, 08:27 AM   #20 (permalink)
Nor me...hahaha......lol
What's up with oil pressure?? Agent 007 SRT8-Specific General Discussion 3 01-27-2012 02:10 AM
Oil Pressure 99 Psi? kraelo SRT8-Specific Performance & Engine/Intake/Exhaust Mods 3 04-05-2011 07:25 PM
Oil Pressure Beancounter General Discussion 1 10-23-2008 01:20 PM
Air Pressure? splifrover Custom Wheels & Tires 0 05-28-2006 10:15 AM
where is your oil pressure? marlinspike SRT8-Specific General Discussion 11 10-09-2005 07:39 PM
