Go Back   Chrysler 300C & SRT8 Forum > Chrysler 300 & All LX Models Forums > European & Diesel Powered 300 Models
Old 09-23-2007, 12:50 PM   #1 (permalink)
tadpole
Car: 2007 Chrysler 300C CRD
Member Number: 13331
CRD, 0-60 mph time
I now have 732 miles on the clock and thought it time to check out the acceleration. I only tried it the once and got 0-60 in 7.58 seconds. Conditions were; dry road, not much wind, slight incline up and a bit of wheel slip on moving away.
This was starting from engine tickover. A better result would be by holding with the footbrake on start and 2000 rpm for maximum torque.
tadpole is offline
Old 09-23-2007, 01:12 PM   #2 (permalink)
quonker
Member Number: 13146
Funny really as I gave mine its first 0-60 today, car was collected on 1st Sept on a 57 plate and now has 2800 miles on the clock.
Had a full tank of fuel with a boot full of shopping and a wife in car and with the same procedure, i.e. just floor the pedal managed 7.38, although of course I have a chip that I bought from ebay fitted.
Conditions were flat and dry.
Will try again with a nearly empty tank, without wife and shopping, and will use the brake pedal until 2000 revs reached, should be interesting!
Has anyone tried to measure these readings to see if they are accurate?
quonker is offline
Old 09-24-2007, 04:58 AM   #3 (permalink)
Fadboy
Fadboy's Avatar
Car: 2007 chrysler 300c crd
Member Number: 11373
try this
http://www.300cforums.com/forums/eur...0-records.html
Hop in my Chrysler, it's as big as a whale and it's about to set sail! (love shack)
Fadboy is offline
Old 10-02-2007, 03:24 PM   #4 (permalink)
tadpole
Crd 300c
Tried 0-60 for the second time today. Took off from a layby and reached 60mph in 7.18 secs.
tadpole is offline
Old 10-08-2007, 12:23 PM   #5 (permalink)
tadpole
Today, third test, now down to 0-60 in 7.00 secs
tadpole is offline
Old 10-11-2007, 04:26 AM   #6 (permalink)
300C-CRD
Car: 2006 Chrysler 300C-CRD
Member Number: 10702
Two tonnes of metal plus driver, 7.0 seconds is an awesome time. Never tried it myself, someone told me how to do the timing before but I forgot now. After having fitted a "Tunning Box" I noticed the pick up has improved. Better check up the old threads on how do the timing.
300C-CRD is offline
Old 10-11-2007, 04:52 AM   #7 (permalink)
300C-CRD
Just found out how to do the timing, some of time recorded by other member were amazing in the 0-60 records.
300C-CRD is offline
Old 10-16-2007, 07:31 PM   #8 (permalink)
steelblue300c
steelblue300c's Avatar
Member Number: 14011
Anyone using a Superchip? My local dealer can re programme the ECU with a 55bhp increase that is completely undetectable for 500 squid. One of his regular customers with many chipped cars says its the most effective re map done so far. Any takers ... whos already done it???!!
steelblue300c is offline
Old 10-17-2007, 02:25 AM   #9 (permalink)
300C-CRD
Don't think many members will openly admit to remap their cars until the warranty runs out. Fitting a tunning box will (allegedly) increase the power by 51 hp to 269 hp and touqe by 70 Nm to 580 Nm. A tunning box can be removed easily without a trace. 0-60 should be below 7 sec without trying too hard. (disclaimer: nor I have one fitted or tried - fingers crossed)
300C-CRD is offline
Old 10-17-2007, 03:55 AM   #10 (permalink)
corfew
corfew's Avatar
Car: 2006 Chrysler 300C CRD
Member Number: 7148
Me too. Racetune (:: Phil Whitaker Cars - Used Volvo Cars - Buckinghamshire :: Welcome to PWCars) "allegedly" increase bhp from 218 to 275 and torque from 510 to 620. That should make a slight difference I'm told......
All my Christmas' have come at once!!
Startech Grill
Rear Tints
Sat Nav
Rear DVD Player
Woodcraftman Internal Trim
corfew is offline
