Go Back   Chrysler 300C & SRT8 Forum > Chrysler 300 & All LX Models Forums > European & Diesel Powered 300 Models
Old 03-26-2008, 05:17 AM   #1 (permalink)
Fadboy's Avatar
Car: 2007 chrysler 300c crd
Member Number: 11373
Noisy front suspension
Hi
I am having my first service tomorrow, only fault to complain of is the auto up drivers window only sometimes works (even after doing the holding of the button fix). The other slight worry is the noise of the front suspension when going over a meduim sized road hump at more than 10mph, it sound very loud and "not right". I can obviously go over these below 10mph to not get the noise but I was wondering if this has been noticed by anyone else?
Cheers
Hop in my Chrysler, it's as big as a whale and it's about to set sail! (love shack)
Fadboy is offline
Old 03-26-2008, 05:29 AM   #2 (permalink)
derick's Avatar
Car: New in Dec 2006 chrysler 300C CRD
Member Number: 15282
Location: Nazeing ,Essex,England 25 miles north of London
Send a message via AIM to derick
Hi, haven't noticed the noisy suspension but certainly have the intermittent problem with the auto windows. Let us know how you get on at the dealership as I'm having my wheels replaced on Monday and may well mention the problem as well.
Derick
50DD
Only in Britain do we leave cars worth thousands of pounds on the drive and lock our junk and cheap lawn mower in the garage.
We also have a tendency to drive a foreign car, drink Australian beer in an Irish pub, grab an Indian curry or a Turkish kebab on the way home, where we sit on Swedish furniture and watch American shows on a Japanese TV. Rule Brittania
derick is offline
Old 03-26-2008, 05:56 AM   #3 (permalink)
Car: 2007 Chrysler 300C CRD Bright Silver
Member Number: 14853
Hi,
its funny you should mention this, I have noticed that when my car is on full lock reversing out of my or my parents driveway, I sometimes get a clunk as it drops down the inch or so off the run up/cross over into the road itself.
I was not too alarmed about this as my Mazda 6 did it too, but it has been bothering me.
I also have a Rover 214 (Dont ask) and used to have a Lotus Elise neither of those done it.
Steve.
sdm197 is offline
Old 03-26-2008, 06:04 AM   #4 (permalink)
Euro & Overseas Moderator
watsonofearnock's Avatar
Car: 2007 Chrysler 300C CRD Touring in Mineral Grey
Member Number: 13042
Regarding the auto up window problem - I had this when I first got the car. Back to the dealership who put in a new "sensor" on the driver's door. It didn't make any difference. Took it back in and showed them together with a N American TSB which suggested that it could be a problem with static blowing the sensor from body movement over the seat. However nothing daunted the garage reckoned that the cure was to replace both the driver's door sensor AND THE PASSENGER DOOR SENSOR at the same time. They took the car back in and apparently did that - that was back in September and the window auto up feature has been fine ever since. You should speak to the garage before it goes in - give them a chance to order in the parts.
For some strange reason I can occasionally get a clunk from the front suspension when turning on full lock in a car park with a painted surface. However I used to get exactly the same knock from my Merc at exactly the same part of the car park - so I don't reckon it is anything to worry about.
Hope this helps.
Cheers John
NOW? --- IT SAY'S IT ALL!!
watsonofearnock is offline
Old 03-26-2008, 06:11 AM   #5 (permalink)
Greenheugh's Avatar
Car: 2006 Chrysler 300C 5.7 Estate
Member Number: 15102
Derick
What's this about wheels? Lots of us seem to have complained of wheel corrosion.
G.
Startech front spoiler, LED sills, special exhausts, door lock pins, Monostar IV wheels 20" x 9" with 275/35x20 & 245/40x20 tyres.
Clear corners, Edashkit 82-piece OEM Californian Walnut dash, 22Elite padded console cover & elbow pad, Myrtle wood rim steering wheel, Halfords chrome valve caps.
Greenheugh is offline
Old 03-26-2008, 12:14 PM   #6 (permalink)
UK CHRYSLER 300C's Avatar
Member Number: 12398
get your track rod ends ckecked for play,its a common fault,but after thats been done I bet my last pound your steering rack will have some play in it six months down the line.It happened to my "C"
UK CHRYSLER 300C is offline
Old 03-27-2008, 07:00 AM   #7 (permalink)
scramp28's Avatar
Member Number: 12849
My suspension creaks, like an old bed front and back, over bumps. It seems worse when its cold and there's salt on the road.
scramp28 is offline
Old 03-27-2008, 09:46 AM   #8 (permalink)
That sounds like to me worn bushes somewhere and theres quite a few bushes,take it back if its still under warranty and let them sort it out
Old 03-27-2008, 10:14 AM   #9 (permalink)
BigIan's Avatar
Car: 2006 Chrysler 300C 3.0 V6 CRD
Member Number: 15047
Originally Posted by Fadboy View Post
Hi
Cheers
I had a similar thing a knock when going up little bumps or steep road humps, DC sorted it under warranty. Replaced a link and bush I think!!??
This is my 300C, there are many like it, but this one is mine.
I must master it as I must master life,
Without me, my 300C is useless
Without my 300C, I am useless.
BigIan is offline
Old 03-27-2008, 10:23 PM   #10 (permalink)
Member Number: 232
You may need to grease your front sway bar bushings. My Hotckis sways made the same noise and needed grease. But it appears from your pic that you may have the stock sway bars, which shouldn't need grease.
joey is online now
