European & Diesel Powered 300 Models This section is for topics relating to the EU versions of the Chrysler 300 and diesel powered models
300cForums.com is the premier Chrysler 300C forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 11-17-2008, 03:51 PM   #1 (permalink)
pnp
Points: 1,119, Level: 1 Points: 1,119, Level: 1 Points: 1,119, Level: 1
Member Number: 15732
On board computer message
Hi,
I tryed the Easter Eggs computer thing and I have a message that doesn't apper on that topic.
I attached a picture of it.
My doubt is this: there's a graphic going from 0 to 700 and the pressure value displayed is 795.
Is there something wrong with engine oil pressure?
Thank's for the help...
pnp is offline
Old 11-17-2008, 05:35 PM   #2 (permalink)
Points: 2,027, Level: 1 Points: 2,027, Level: 1 Points: 2,027, Level: 1
Declan (Dublin)'s Avatar
Car: 2008 Chrysler Black,300 CRD SRT Design, Startech SD6, MyGig Nav., Tints
Member Number: 11816
Yep! I had this on my 2006 model, but I never did anything about it.
I don't think there is an oil pressure problem just the sensor is out of range.
Declan (Dublin) is offline
Old 11-17-2008, 08:16 PM   #3 (permalink)
pnp
The picture I didn't attatched...
pnp is offline
Old 11-17-2008, 08:18 PM   #4 (permalink)
Points: 56,645, Level: 1 Points: 56,645, Level: 1 Points: 56,645, Level: 1
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
car's not running?
does it change when the car is running?
some of the sensors will read odd things when the motor isn't running..
my Temp reading in the EVIC shows 400 degrees F when the motor is off but the key is in Run..
Mr. iNCREDIBLE is offline
Old 11-17-2008, 08:41 PM   #5 (permalink)
pnp
Yes, it does. Both stopped and running.
The picture was taken just after I got home, so the engine was hot.
pnp is offline
Old 11-17-2008, 08:43 PM   #6 (permalink)
Member Number: 5683
Trader Rating: (21)
sorry it does what? shows the same thing stopped or running?
Old 11-17-2008, 09:10 PM   #7 (permalink)
pnp
Yes, does the same thing stopped and running.
pnp is offline
Old 11-17-2008, 09:12 PM   #8 (permalink)
Member Number: 5683
Trader Rating: (21)
either bad sending unit or the cluster has an issue, either way i suspect a dealer is required..
should be a warranty item.
Old 11-17-2008, 09:39 PM   #9 (permalink)
pnp
Declan had the same thing bt never had any problem with it.
The problem is that in my country dealers are clueless about these cars since there are so few of them...
pnp is offline
Old 11-18-2008, 12:53 AM   #10 (permalink)
Points: 2,545, Level: 1 Points: 2,545, Level: 1 Points: 2,545, Level: 1
Russell's Avatar
Car: 2006 chrysler 300c srt8
Member Number: 19380
i had that before. it means your doors open.
Russell is offline
