Dam!.... played with the jumpers and MIL light won't go off - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 09-03-2011, 07:20 AM   #1 (permalink)
Points: 29,933, Level: 1 Points: 29,933, Level: 1 Points: 29,933, Level: 1
tim@thecustom300cshop's Avatar
Car: 2006 Chrysler 300c CRD
Member Number: 37143
Question Dam!.... played with the jumpers and MIL light won't go off
Played with the Spider jumpers yesterday (moved them up) and this morning after a boot full got the sulk mode (ETC flashing) and MIL light.
Moved jumpers (Revs & Power) down one and no more sulk mode/ETC but MIL light still on. Cars been stopped started a couple of times, will it go out when it decides everything is 'hunky dorey' (if so how long/how many miles) or does it need turning off?
If anyone knows the optimal jumper settings for the Spider please tell (9 rows of 3 pins/top = revs/bottom = power.... I think)
tim@thecustom300cshop is offline
Old 09-03-2011, 02:27 PM   #2 (permalink)
Major Contributing Member
Points: 6,997, Level: 1 Points: 6,997, Level: 1 Points: 6,997, Level: 1
GrumpyBob's Avatar
Car: 2009 Chrysler 300C Touring SRT Design (HSZ)
Member Number: 24976
When I had a Drake2 on mine I tried it on both 7 & 8 both of which caused the BONG/FLASH result when booted. The amber engine shaped light stayed on for a while although the car ran ok. I think it reset itself after about 5 normal starts.
Chrysler/Brink Detachable Towbar
Billet Tech Catch Can
Alternator Shroud
BMC Performance Panel Filter
12 LED DRL's
Larger Intercooler
Viezu V-Switch
H&R TRAK+ 30mm Wheel Spacers
Software
Application: 2.403
Gracenotes: 2059
GrumpyBob is offline
Old 09-03-2011, 02:35 PM   #3 (permalink)
Thanks Bob, The car runs ok i.e. no limp mode, so it seems it'll just be a waiting game for the MIL light to go off then
Old 09-03-2011, 03:00 PM   #4 (permalink)
Points: 6,573, Level: 1 Points: 6,573, Level: 1 Points: 6,573, Level: 1
SRT ROB's Avatar
Car: 2009 Chrysler 300C SRT CRD
Member Number: 25646
If it doesn't go off on your drive tomorrow, I would disconnect the battery for a minute or so and it should go off, this worked on my bro's car when his went into limp mode.
2013 JEEP GRAND CHEROKEE LIMITED S
DIESEL CHIP - 1.25" WHEEL SPACERS - MGP CALIPER COVERS - BLACK JEEP BADGE
SRT ROB is offline
Old 09-03-2011, 03:02 PM   #5 (permalink)
Points: 42,254, Level: 1 Points: 42,254, Level: 1 Points: 42,254, Level: 1
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Member Number: 21130
I had a MIL that went off at Cirencester having started at S'Hampton, if that gives you an idea?
A longish battery disconnect works usually too.
I'm expecting one en-route to Towcester - I did the t-stat today
Watching You Avoiding Me!
Kaiser Bill is offline
Old 09-03-2011, 03:11 PM   #6 (permalink)
Well hopefully then it'll go off in the morning, if not prap's I'll disconnect the battery whilst we're at the event, although don't you have to reset loads of stuff... window, stability thingy etc?
Old 09-03-2011, 03:16 PM   #7 (permalink)
nope....at least I never have
Old 09-03-2011, 03:55 PM   #8 (permalink)
Points: 14,418, Level: 1 Points: 14,418, Level: 1 Points: 14,418, Level: 1
Armchair's Avatar
Car: 2009 Chrysler 300c crd SRT Design
Member Number: 28455
Mine seemed to reset itself... apart from the window. I had to do that myself.
Armchair is offline
Old 09-04-2011, 08:42 AM   #9 (permalink)
Points: 24,961, Level: 1 Points: 24,961, Level: 1 Points: 24,961, Level: 1
Activity: 92% Activity: 92% Activity: 92%
Member Number: 37145
Here's the instructions you wanted for the Spider
Dam!.... played with the jumpers and MIL light won't go off-spider1.jpg   Dam!.... played with the jumpers and MIL light won't go off-spider2.jpg
Old 09-04-2011, 02:51 PM   #10 (permalink)
Cheers Simon, managed to turn the MIL out with Miles's Predator. He just plugged it in and although it wouldn't allow deletion of the code (Fuel Rail Pressure) on next IGN turn after removing the predator the MIL went off.
Not convinced I have the Spider at its optimum, still doesn't feel as yours did when I tried it.
Are DUB Moguls played out? bluv4eva Custom Wheels & Tires 15 03-25-2009 04:16 PM
How To Allow DVD's to be played while in motion?? 300C2NV Car Audio/Alarms/UConnect/Navigation 7 02-26-2007 04:13 PM
Am I getting played? marnepup SRT8-Specific General Discussion 10 05-17-2005 10:29 AM
Played with E46 M3 and a Honda S2000 slk320 General Discussion 2 05-01-2005 01:48 PM
Why the 300C is getting played out 300PMP General Discussion 34 01-26-2005 09:43 PM
