Swirl Motor - cheap replacement solution (Pennies!) - Page 4 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 06-01-2012, 03:00 PM   #31 (permalink)
Major Contributing Member
Points: 7,758, Level: 1 Points: 7,758, Level: 1 Points: 7,758, Level: 1
devilmaycare's Avatar
Member Number: 7282
Unless Boro al has a better method, I would try and obtain a couple of spade terminals to fit the cable socket and solder the resistor(s) to them.
devilmaycare is offline
Old 06-01-2012, 03:36 PM   #32 (permalink)
Points: 18,204, Level: 1 Points: 18,204, Level: 1 Points: 18,204, Level: 1
Boro al's Avatar
Car: 2007 chrysler 300c SRT8 tourer, (00A)
Member Number: 22259
Originally Posted by devilmaycare View Post
Boro al, could you provide details on how you wired in the resistor? Would you be able to easily re-connect the swirl motor if necessary?
Here you go,
Because this was a trial I didn't want to cut the wiring so decided i would fit the resistor by inserting the tails of the resistor into the pin holes of the plug.
on my car the plug wiring was below a bracket that secures the turbo and swirl motor to the head so the bracket had to be removed to allow the plug and wiring to be accessible,the bracket was refitted with the plug removed but it is possible to refit the plug with the bracket in place if required.
It's possible that a car that's had the swirl motor replaced may have the plug accessible without removing the bracket.
all i did was double over the end of the tails and push them into the pin holes and secured it with some insulating tape wrapped around the plug and resistor,the plug is laid on top of the fuel filter, if i need to refit the plug it is just a five minute job to remove the intake pipe and refit the plug.
The resistor is connected to the live and signal wires which are red/green and grey on the crd, these are actually the two centre connections on the plug, it is a four pin plug with three wires.
I'm not the best at explaining things so hopefully you can follow my direction and good luck if you give it a try.
2006 56 crd tourer Mineral Grey.SOLD
Dec 2007 SRT8 Black tourer with Tints.SOLD
2006 MERC C320 v6 cdi in Black. SOLD
2006 MERC E280 V6 CDI Estate in Blue.
Boro al is online now
Old 06-01-2012, 03:42 PM   #33 (permalink)
Boro al's Avatar
As you say a couple of matching spades would do the job if you do not want to cut the wiring.
It is worth mentioning that the connection can be made at the pcm,you only need to locate the grey signal wire and the live can be picked up under the fuse box for example.
The Following User Says Thank You to Boro al For This Useful Post:
devilmaycare (06-01-2012)
Old 06-01-2012, 04:32 PM   #34 (permalink)
Member Number: 7282
Thanks for the info, Boro al. It looks as if your method would be similar to the one I would use, should the need arise. I'm not sure I want to take this pre-emptive measure at the moment, but I can see the sense in avoiding the consequences of a swirl motor failure caused by the flaps jamming in a closed or intermediate position. Perhaps you could keep us updated on your car's performance with this mod after you've clocked up a few more miles?
Old 06-01-2012, 05:30 PM   #35 (permalink)
Boro al's Avatar
It was done as a trial so while it is running ok i will leave it as is and see how it goes.
Old 06-02-2012, 02:55 AM   #36 (permalink)
Points: 54,695, Level: 1 Points: 54,695, Level: 1 Points: 54,695, Level: 1
Activity: 44% Activity: 44% Activity: 44%
Car: Chrysler 300c 2009 CRD
Member Number: 37144
What type of resistor was it?
www.custom300cshop.co.uk
Old 06-02-2012, 02:57 AM   #37 (permalink)
found it, would these do the Job??
http://www.ebay.co.uk/itm/4K7-OHM-4-...#ht_3073wt_982
Old 06-02-2012, 08:13 AM   #38 (permalink)
Points: 1,894, Level: 1 Points: 1,894, Level: 1 Points: 1,894, Level: 1
matrix1975's Avatar
Car: 2008 Chrysler 300C CRD [YNK]
Member Number: 27470
done it
Ok, I've done it.
It works. Walked down to Maplin bought a 4.7K resistor for 26p.
Came home, disconnected the dead Swirl Motor and just inserted the resistor into the Swirl Plug pings on the Grey PWM signal wire and the live Red/Green wire. The middle two on mine.
Ignition on, cleared codes on OBDII reader and fired her up. No further DTC codes, no MIL light, no ETC light.
Now its confirmed, I'll do a proper connection on it with spade connectors etc.
Big thanks to all those who've offered advice!!
Swirl Motor - cheap replacement solution (Pennies!)-mtx1975_photo1.jpg   Swirl Motor - cheap replacement solution (Pennies!)-mtx1975_photo2.jpg
matrix1975 is offline
The Following 5 Users Say Thank You to matrix1975 For This Useful Post:
Gouldy (09-28-2012), Graziano_1963 (10-25-2012), Kaiser Bill (06-02-2012), suzieque (06-02-2012), wookiee (06-06-2012)
Old 06-02-2012, 08:27 AM   #39 (permalink)
Boro al's Avatar
Well done, Thats two of us now confirmed as ok, I can see a big drop in swirl motor sales.
Old 06-02-2012, 08:47 AM   #40 (permalink)
Really great result, definately worthy of a STICKY and a post in the "how to section" thumbs up
The Following User Says Thank You to paul@thecustom300cshop For This Useful Post:
Swirl motor emulator - a UK solution? Armchair European & Diesel Powered 300 Models 217 06-22-2012 02:40 PM
Swirl motor pictures and replacement instructions suzieque European & Diesel Powered 300 Models 8 06-22-2012 01:41 PM
Swirl Motor replacement, do I need new manifold too? dannyfiveforty European & Diesel Powered 300 Models 7 11-16-2011 05:31 AM
Swirl motor replacement photos suzieque European & Diesel Powered 300 Models 2 03-20-2011 03:45 AM
Replacement swirl motor Berliner Uwe European & Diesel Powered 300 Models 9 03-06-2011 05:03 PM
