Old 06-14-2004, 11:41 AM   #11 (permalink)
Abshear7
Member Number: 121
Doc, just ordered my fog lights, please advise if there's anything "odd" on the install; thanks.
Abshear7 is offline
Old 06-14-2004, 02:34 PM   #12 (permalink)
Doc G
Doc G's Avatar
Member Number: 168
Will try and get some pics later on this week. I forgot my camera in Louisiana. I had my dealer change all my bulbs. Cost me $30 for labor
Doc G is offline
Old 09-13-2004, 09:40 PM   #13 (permalink)
scandaloustrick
scandaloustrick's Avatar
Member Number: 560
I recently purchased slyvania silver star bulbs for my low beams, high beams and turn signal and found that all three did not fit correctly. It seems that on the bulb assembly each have a very small tab that is needed to lock the bulb in place. All the different bulbs assembly little tabs are centered, rather than the stock bulbs tabs seems to be offset a bit. I went to one custom shop and two different Pepboys and came to the same conclusion on all three bulbs set at all three stores. I believe that kev55 described in a thread that he had installed these bulbs but unless he had special ordered them, all retail stores bulbs seem to come the same. It may be because these bulbs are different for 2005 cars or he forced them in somehow.
In conclusion, if anyone has purchased slyvania silver star bulbs, 9006 (low beam), 9006 (high beam), and 3057(turn lamp) please help!!!!
Dave
Chicago
scandaloustrick is offline
Old 09-14-2004, 02:32 PM   #14 (permalink)
"C"for me
Member Number: 295
I did silverstars for low (projector) and high beams in my 300C. Not a problem except you need to remove the airbox to get at the drivers side bulbs. Work just great. They were "normal" and just slipped into place, like the stock bulbs. Kinda rotated to fit in as I recall.
"C"for me is offline
Old 09-15-2004, 12:32 AM   #15 (permalink)
Scarbs
Scarbs's Avatar
Car: 2005 Chrysler 300 C
Member Number: 446
Hid
OK
So HID is just a bulb replacement i dont have to have any speical wireing or have had it from the factory
Scarbs is offline
Old 09-15-2004, 06:58 AM   #16 (permalink)
cmego
Member Number: 649
Scar,
HID involves much more than just bulbs; there is a high-voltage power supply that needs to be wired in. Silverstars are just a fancier model of halogen bulbs, same wattage as stock but supposed to be somewhat brighter and whiter. Sylvania also has a "blue" halogen drop-in that is not any brighter than stock but gives the "look" of HID.
cmego is offline
