Old 01-26-2005, 01:22 PM   #1 (permalink)
300 on 22s's Avatar
Member Number: 565
If u have an e&g grill please read---help.
Just wondering I installed the e&g center bar grill yesterday and noticed one side on the bottom of the grill seems to sit a little more in then the other side its not by much I tried looking at other pics of people and it looks liek every1's else is the same be 4 i go mess around and try to tighten it down some more just wondering if any1 else noticed this. I'm pretty sure that i drilled the holes right cause all the studs lign up and the top and the side othe grill fits perfect it just a drop on the bottom. Just wondering I know nothing aftermarket ever ligns up perfect
300 on 22s is offline
Old 01-27-2005, 08:24 AM   #2 (permalink)
300 on 22s's Avatar
Member Number: 565
well any 1
Old 01-27-2005, 08:45 AM   #3 (permalink)
II kings 9:20's Avatar
Car: 2005 Hemi 300C
Member Number: 132
Mine seems symmetric and even and lines up perfect. I have larger pics in my recent before and after fog thread. When you say "sit" do you mean crooked or slanted. My grille opening is tight and took a little work get it in cause I did not enlarge my holes enough . I would think if your holes are large enough, you should be able to just loosen the nuts, shift and re tighten, you will need an extra set of hands.
II kings 9:20 is offline
Old 01-27-2005, 08:46 AM   #4 (permalink)
myrtle300c's Avatar
Member Number: 653
grille
Mine was very uneven when initially installed. I went back and added washers to the screw posts that were lower than the rest to push it out and even it up..
myrtle300c is offline
Old 01-27-2005, 12:13 PM   #5 (permalink)
300 on 22s's Avatar
Member Number: 565
its about 2 cm diff on the bottom part of the frill one side just sits in a little more flush than the other i think ill just leave it now and when i get bored one day and decide to spray paint that plastic piece ill mess aroun with it
Old 01-27-2005, 09:17 PM   #6 (permalink)
Car: 2005 Hemi 300C
Member Number: 132
I hope you mean mm and not cm
