Old 08-26-2007, 05:52 AM   #1 (permalink)
dunsantos's Avatar
Member Number: 12260
Which fuse for the license plate lights?
Anyone know which fuse is used for the license plate lights in the rear? I can't find it and seemed to have "misplaced" my manual.
________2005 Midnight Blue 300C__________
dunsantos is offline
Old 08-26-2007, 06:02 AM   #2 (permalink)
BAG-63D's Avatar
Car: MY2006 White 300c HEMI
Member Number: 11978
LOL like 30 minutes ago i was wondering the same thing!!! never found out though hahahahahaha.
Replaced the bulbs and it was all good.
Interested to find out though
BAG-63D is offline
Old 08-26-2007, 06:05 AM   #3 (permalink)
dunsantos's Avatar
LOL that's funny. I wish there was a fuse diagram of some sort, you know? Not sure if something like that was in the manual or not.....
Old 08-26-2007, 07:36 AM   #4 (permalink)
bigsnake's Avatar
Member Number: 10476
You have me laughing too. I have a fuse diagram right in front of me and don't see a direct link to the license plate light. The closest I can come is under the hood no. 8 fuse(15 amp dark blue) which is listed for the park lamps and controls the relays. Good luck!
SRT8 OPENS A CAN OF
300C SRT8 _ Charger R/T
Mods:
Mopar CAI
Centric Posi-Quiet brake pads
Stealth SRT8 Pedals
Mopar Locking Gas Cap
Billet Tech Catch Can
Motorad 180 T stat
bigsnake is offline
Old 08-26-2007, 07:53 AM   #5 (permalink)
dunsantos's Avatar
Hey man, you think you could scan that diagram in and post it? It would be a good to have online.
Old 08-26-2007, 09:44 AM   #6 (permalink)
bigsnake's Avatar
Power Distribution Centers
Hope this helps!
Front Power Distribution Center Fuses
A power distribution center is located in the engine compartment. This center contains fuses and relays.
CAUTION:
  • When installing the Power Distribution Center cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Power Distribution Center, and possibly result in a electrical system failure.
  • When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected.
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer — If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ — —
13/ — —
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ — —
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
There is also a power distribution center located in the trunk under the spare tire access panel. This center contains fuses and relays.
CAUTION:
1/ 60 Amp Clear/ Ignition Off Draw
2/ 40 Amp Green/ Battery
3/ — —
4/ 40 Amp Green/ Battery
5/ 30 Amp Pink/ Heated Seat/Steering Column
6/ 20 Amp Yellow/ Fuel Pump
7/ — —
8/ 15 Amp/ Dk. Blue Ignition Start/Run - Start
9/ 20 Amp Yellow/ Console Power Outlet
10/ 10 Amp Red/ Rear Fog Lamp — If Equipped
11/ 25 Amp C/BRKR/ Memory Module/Door Locks
12/ 25 Amp C/BRKR/ Passenger Power Seat
13/ 30 Amp C/BRKR/ Door Module Run/Acc/Delay
14/ 10 Amp Red/ Sentry Key/Remote Keyless Entry/Cluster
15/ 20 Amp Yellow/ Brake Light (5.7L)
16/ 20 Amp/ Yellow/ Power Outlet Trunk - if equipped
17/ — —
18/ 20 Amp/ Yellow Selectable Power Outlet
19/ 10 Amp/ Red Stop Lamp
20/ 20 Amp Yellow Rear Wiper — If Equipped
21/ — —
22/ — —
23/ — —
24/ — —
25/ — —
26/ — —
27/ 10 Amp Red/ Airbag/Occupant Classification Module
28/ 10 Amp Red/ Curtain Airbag - if equipped
29/ 5 Amp Orange/ Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30/ 10 Amp Red/ Steering Column Module/Power Mirrors - if equipped
31/ — —
32/ — —
33/ — —
34/ — —
35/ 5 Amp Orange/ Power Antenna/Garage Door Opener/Ignition Delay
36/ 20 Amp Yellow/ Radio/Navigation
37/ 15 Amp Dk. Blue/ Transmission
38/ 5 Amp Orange/ Analog Clock/Garage Door Opener / trunk light (charger)
39/ 10 Amp Red/ Heated Mirror
40/ 5 Amp Orange/ Power Mirror
41/ 10 Amp Red/ Climate Control Module/Headlamp Leveling — if equipped/Rear Park Assist — if equipped/Tire Pressure Monitoring — if equipped
42/ 30 Amp Pink/ Automatic Temperature Control (ATC) Blower Motor
43/ 30 Amp Pink/ Rear Defroster
44/ 20 Amp Lt. Blue/ Audio Amplifier / sunroof
bigsnake is offline
Old 08-26-2007, 12:16 PM   #7 (permalink)
BobF's Avatar
Car: 2008 Chrysler 300C SRT8 - Bright Silver Metallic
Member Number: 3361
Fuse #8 in Front Panel. It's in the owners manual. It says #8 - 15A, Blue - Lights, License, Park, Side Marker, Stop, Turn. Regards, Bob.
BobF is offline
