Old 03-29-2005, 05:56 PM   #1 (permalink)
ink
ink's Avatar
Member Number: 1711
front fascia clips reusable??
Once you remove these clips can they be reused and put back in again or do you need to buy new ones? I dont see how they can be pushed back in given the way they look. Also, how do they come out? I have tried pulling pretty hard on mine and they dont seem to want ot come out. Any suggestions? Thanks
ink is offline
Old 03-29-2005, 06:29 PM   #2 (permalink)
aspendog's Avatar
Member Number: 69
Trader Rating: (15)
They can be reused but it is a PITA to push the shaft back from behind the wheel well. They are designed to be a one time use plastic rivit that actually requires a tool (plastic rivit gun) to install properly. You can also just use a pair of pliers and cut off the excess.
aspendog is offline
Old 03-29-2005, 06:47 PM   #3 (permalink)
ink
ink's Avatar
Member Number: 1711
how do I get them out in the first place? Do I just pull really hard?
ink is offline
Old 03-29-2005, 09:09 PM   #4 (permalink)
aspendog's Avatar
Member Number: 69
Trader Rating: (15)
Just push through the rivit (round center of the fastner) with a pick or a small phillips. If you plan on replacing them just drill it out.
aspendog is offline
Old 03-29-2005, 09:46 PM   #5 (permalink)
ink
ink's Avatar
Member Number: 1711
I did try that the first time and it wouldnt push through.....maybe I just didnt push hard enough? I will try agian.....
ink is offline
Old 03-30-2005, 06:14 PM   #6 (permalink)
TheDon300's Avatar
Car: 2005 Chrysler 300
Member Number: 1042
Send a message via AIM to TheDon300
hey ink can you post a picture of your grille it looks to be black... i would like to see what you have done with your car thanks...
TheDon300 is offline
Old 03-30-2005, 06:45 PM   #7 (permalink)
gossame1's Avatar
Car: 2005 Base 300
Member Number: 858
Send a message via AIM to gossame1
Ink,
These clips are designed, just like Aspendog said, (One Time Use) On Monday, I had to take my 300 in to the shop to have the grille replaced due to damage from some 'idiot' backing into the car. In order to replace the grill, the entire front fascia had to be removed. The dealer used all new fasteners for me. (I see you have a CV 300 as well!-Great Color Choice! ) I hope this information helps....
Sincerely yours,
Brian T. Carotenuto
2005 Chrysler 300-Cool Vanilla with Medium/Dark Slate Grey cloth interior with ESP package
gossame1 is offline
Old 03-31-2005, 06:09 PM   #8 (permalink)
HERMINIO's Avatar
Car: TWO 2005 Deep Lava Red 300C's
Member Number: 442
ink, you need to cut the head because they are plastic rivets. The oem part #CBCOAO60 and need the following riveter tool to install #HUCPR75 made by Huck.
How-To: OEM Hid Retrofit
Herminio
2005 300C HIS, DLR, WOOD TRIM, D2S HID, PILLAR SET, AIR DEFLECTORS, LIP SPOILER, TINTING, E&G GRILL, LOWER MESH INSERT, PAINTED ENGINE COVER, VES, AIRHAMMER, UC, UNDERHOOD LIGHT, BFG KDWS 245/55/18, PEDALS SET, CHROME TAIL BEZEL
2005 300C HER, DLR, OEM HID RETROFIT, PILLAR SET, AIR DEFLECTORS, WOOD TRIM, LIP SPOILER, TINTING, OEM CABIN FILTER RETROFIT, E&G GRILL, LOWER MESH INSERT, PAINTED ENGINE COVER, VES, AIRHAMMER, UC, UNDERHOOD LIGHT, BFG KDWS 245/55/18, PEDALS SET, CHROME TAIL BEZEL
HERMINIO is offline
Old 03-31-2005, 06:24 PM   #9 (permalink)
300Con23s's Avatar
Car: 2005 Chyrsler 300C
Member Number: 461
When I had my grill installed I had to replace all 6 for $7. The guys at the shop I had it done didn't have the proper tool and were able to use a piler but you should find a place that has a proper tool.
Car(s):
- 2005 Silver 300C fully loaded with 26,xxx km's
- 2008 Silverstone BMW M3 "coupe"
Mods:
- 22" TIS 03's w/Pirelli Tires
- VIP300C front lip
- REC navigation with Mopar IPOD
- Huper Optik tinted windows
- Eibach 1.6" drop
- Demolded
- E&G grille with matching lower vent mesh
- SRT-8 dark grey center console
- Custom black 300C mats
300Con23s is offline
Old 03-31-2005, 07:26 PM   #10 (permalink)
ink
ink's Avatar
Member Number: 1711
Unfortunately this is not my car...it is a car done by West Coast Customs....but I wish it was mine! When mine is done I will replace the avatar with my car
Thanks for the info guys. Maybe I will pick up one of those rivet guns as they are only $30 and probably a good thing to have laying around.
ink is offline
