Old 01-30-2008, 02:06 AM   #1 (permalink)
jauggie81's Avatar
Car: 2006 chrysler 300 limited
Member Number: 16395
Rear Trunk Emblem
whats up everyone..quick question for ya...does the wing on the trunk come off pretty easy? is just held on by double sided tape? I was looking at taking it off but didnt want to ruin anything in the process....thanks for the help
jauggie81 is offline
Old 01-30-2008, 02:35 AM   #2 (permalink)
Car: 1979 Chrysler CM regal
Member Number: 12350
Hey there i'm pretty sure i heard a bunch of guys that owned 300's talking about this. From what they were saying the main trunk emblem is bolted on which means you would be left with holes if you removed it. I haven't checked to see if this is the case yet.
hemi6kid is offline
Old 01-30-2008, 03:44 AM   #3 (permalink)
shoeboy23's Avatar
Car: 2008 Chrysler 300C SRT8
Member Number: 14554
Send a message via MSN to shoeboy23 Send a message via Yahoo to shoeboy23
take it off and you will be left with TWO holes.
http://aaronschubbe.com/
http://tamiyaclub.com/member.asp?id=6064 <---click the showroom tab
Shoeboy....
2008 300C SRT8 (Brilliant Black)
Option Groups 1 & 2
Power Sunroof
13 Kicker SRT High-Performance Speakers...
everything except the rear seat DVD player.
...20% tint all around.
shoeboy23 is offline
Old 01-30-2008, 12:21 PM   #4 (permalink)
jauggie81's Avatar
thanks for the help...im gonna put something over it but didnt know if it came off pretty easy...so does that mean you have to go thru the trunk to get it off?
Old 01-30-2008, 12:47 PM   #5 (permalink)
2008chryslerblack's Avatar
Car: 2008 chrysler 300
Member Number: 16344
No, just pull up the double stick tape, use some goo gone to get the residue off, and there are just two holes where the pegs go. No screws or bolts.
I just took mine off, now I'm trying to find someone to fill and paint the holes.
2008 Chrysler 300. Brilliant black.
Black Bentley grille.
Blacked out side markers.
Black lower window trim.
No moldings/badges.
Cleared out headlights.
5% tint all around.
2008chryslerblack is offline
Old 01-30-2008, 01:05 PM   #6 (permalink)
jauggie81's Avatar
did you heat it before you took it off?
Old 01-30-2008, 01:13 PM   #7 (permalink)
X AMOUNT's Avatar
Member Number: 8799
I removed my rear trunk wing on my '08. I took the upper trunk liner down and could just catch a glimpse of a pin through one of the holes. However, there was no nut, just a blob of adhesive. During the heating and removal, it pulled off with the pin clean, as in the picture. Also pictured is the trunk without the emblem, showing the two alignment holes.
I had already planned to shave the trunk when I removed mine. If you'd like to reuse your emblem, beware of overheating and overbending the emblem in the process, as overheating will wrinkle the chrome coating and crack it. WD40 and microfiber help the process so the paint doesn't get scratched.
Good luck with your mod. Look forward to seeing the results!
Gone But Not Forgotten: 05 Satin Jade 300C
X AMOUNT is offline
Old 01-30-2008, 01:41 PM   #8 (permalink)
I didn't heat mine, just pulled up and the two wings slowly toward the center. I'm sure if you heat it, it may come off clean with the tape, but I had no problem removing the tape with my fingers and a little goo gone on a rag after. I didn't go through the trunk.
Old 01-30-2008, 01:50 PM   #9 (permalink)
Member Number: 14270
u can also use dental floss and then use something like the 3m adhesive remover to get rid of any residue.
bund is online now
Old 01-30-2008, 01:53 PM   #10 (permalink)
jauggie81's Avatar
hey thanks for the help....and i take it is the same with the 300 logo as well
