10-15-2009, 01:36 PM
#5 (permalink)
Member Number: 3755
The skirt should go "above" the lower lip of the fascia, so if it's hanging down after a little while, I suspect you have it installed incorrectly. The screw/bolts are supposed to go through the lower, rear edge of the fascia and into the metal clips of the skirt so that they should screw down tight... mine do. Haven't had a problem on the 300C with them going loose. On the MSRT I actually had my body shop "stiffen" the fascia to help hold it straighter regardless of whether the skirt was tight or not. The skirt alone wasn't doing it and when you had the right angle the lower surface of the fascia looked warped.
The benefit of having the skirt in place is to force frontal air through the radiator vs. dumping it down below the car from the pressure build up in front of the radiator/car... and it also help direct captured air up to a CAI (if you have one) when you remove only the lower side baffle on the driver's side.
But no, you won't hurt anything by not having it in place... although I would expect some flexing (and possibly flapping) of the lower fascia at speed without the skirt present.
