Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Chrysler 300 & All LX Models Forums > Exterior Modifications
Old 11-07-2009, 03:28 PM   #1 (permalink)
Points: 7,900, Level: 1 Points: 7,900, Level: 1 Points: 7,900, Level: 1
loudrims_inc's Avatar
Car: 2005 BB Chrysler 300C
Member Number: 14101
Location: Killadelphia...City of Brotherly Thugs and North Jersey!
Trader Rating: (9)
Send a message via AIM to loudrims_inc Send a message via MSN to loudrims_inc Send a message via Yahoo to loudrims_inc Send a message via Skype™ to loudrims_inc
Halo Wiring?
Hello guys, I am finally working on my halo's for the C. I dont have any wiring instructions so i was hoping someone can help me out with step-by-step instructions. The halos i have are white 8000k CCFL from AAC if that matters. Thanks guys!
Tone's Progress Journal and Mods List with Pix
LUXERY + POWER = GREATNESS
http://www.300cforums.com/forums/signaturepics/sigpic14101_7.gif
loudrims_inc is offline
Old 11-07-2009, 03:42 PM   #2 (permalink)
Points: 8,303, Level: 1 Points: 8,303, Level: 1 Points: 8,303, Level: 1
Activity: 48% Activity: 48% Activity: 48%
yamabob's Avatar
Car: 2007 chrysler 300c
Member Number: 14746
Depends on where you want to wire them to-switch-tail lights?
AFE, Corsa Catback, Predator,HHP High Flow Cats,JBA Shorties,HHP Stage1 cam,HHP CMR tune,6000k HID low & fogs,AAC 6k halos,Original American Illuminated Rear wing 347 rwhp,375 rwtq,20" chrome SRT rep's,rear SRT trunk spoiler,SRT front lip. Luxer interior LED's, Grip grill,22Elite console cover
yamabob is offline
Old 11-07-2009, 03:44 PM   #3 (permalink)
Trader Rating: (9)
i want to wire them to the switch from the headlights
Old 11-07-2009, 05:26 PM   #4 (permalink)
yamabob's Avatar
I check out that wiring in the morning as I wired mine to the Parking lights. At dawn and dusk I can use just the Halo's,which I think looks pretty cool
yamabob is offline
Old 11-07-2009, 07:00 PM   #5 (permalink)
Points: 4,285, Level: 1 Points: 4,285, Level: 1 Points: 4,285, Level: 1
Car: 2006 chrysler 300c AWD BS
Member Number: 7073
Trader Rating: (14)
Send a message via AIM to ajn096/300c AMG
Aac
Hi guys i just got a set from AAC ,CCFLs i thik this was a bad move.Caloud help me ,he did the work and i helped him. the lowbeam rings sized well with the head light, but the highbeam halo ring was i think to small. and there is a big write-up on AAC and these halos.not very good. i'am ordering anoter set of invertors from some were ? not AAC i should have listen ,he told me not to buy from them.
ajn096/300c AMG is offline
Old 11-07-2009, 07:04 PM   #6 (permalink)
Points: 4,295, Level: 1 Points: 4,295, Level: 1 Points: 4,295, Level: 1
tx_bandit's Avatar
Car: 2006 Chrsyler 300C SRT8
Member Number: 15722
Trader Rating: (4)
I used to run CCFL halos, here is how I installed mine so that I could run them with the parking lights.
FYI, I never had any problem with the AAC CCFL halos, I moved to LED halos because they were much brighter and showed better under a Texas sun.
On the back of the 300c headlight housing, find the running light/turn signal bulb socket.
You will find three wires labled 1,2 and 3.
The black wire on the inverter goes to wire 1 and the red wire on the inverter goes to 2
When your halos are connected to this point they come on anytime your parking lights are on. Since the halos are rated at 30,000 hours I just run them all the time. If you turn your headlight switch to the off position the halos are off as well.
Here is a shot showing how the Oracle inverter would connect. The inverter has 3/4 inch long pins on the power supply wires. Simply push these pins all the way into the opening the wire goes into until the pin is completely inserted and no longer visible. You may need to use a tool such as a punch or screwdriver to get the last few millimeters of the pin in.
Then just drape the inverter over the top and double side tape them down.
The inverters draw less than an amp so there are no issues tapping into here.
Don't use wire three or your halos will blink with your turn signals!
As a side note I ran one inverter per halo and was able to connect two inverters to each headlight housing.
One last tip, get some heat shrink tubing and make sure that the plugs that connect to the halos themselves are sealed up water tight.
Shorting across the halo socket is the number one way to kill the inverter.
I cut the plugs off, soldered and heat shrunk wrapped all my connections to ensure they were all water-tight/proof.
tx_bandit is offline
Old 11-07-2009, 10:04 PM   #7 (permalink)
Trader Rating: (9)
Thumbs down **UPDATE** Bad news!
looks like there will be a delay on my "Project: Halo" due to a cracked ring...yes, thats right, i accidentally cracked the large ring so i will need to order a replacement. I sent AAC a PM but i will call Andy Monday morning to place my order...does anyone know off the top of their head, how much one large replacement halo would cost?
Old 11-08-2009, 06:16 AM   #8 (permalink)
yamabob's Avatar
about $ 39 for a replacement ring
yamabob is offline
Old 11-08-2009, 12:34 PM   #9 (permalink)
Trader Rating: (9)
oooooo thats great news bob!! thanks! will update when i get the ring and TXbandit, thanks for the wiring pix, that will come in handy when i continue my project
Old 11-08-2009, 12:45 PM   #10 (permalink)
yamabob's Avatar
That is exactly the way I did mine. I also added short amounts of heavier wire the the inverters so I could mount them outside the headlight assembly. Just solder and use heat shrink tubing.
yamabob is offline
