Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Chrysler 300 & All LX Models Forums > Exterior Modifications
Old 11-18-2009, 12:38 AM   #1 (permalink)
Points: 563, Level: 1 Points: 563, Level: 1 Points: 563, Level: 1
fnkycld's Avatar
Car: 2006 Chrysler 300
Member Number: 22600
How to polish aluminum brake calipers
So you want to polish your brake calipers. This easiest way to do this is if you have an extra set of calipers to work on without taking your car apart and not being able to drive it. In my case I was able to get a set of R/T calipers to work on so that I could replace my V6 brakes.
This will take the good part of 1 day if not 2, depending on how detailed you want to get and the tools that you have access to.
First thing, the list of tools needed to polish aluminum calipers.
1. Air die grinder, (this can be done by hand if you do not have access to an air compressor, it just might take a little longer) an orbital sander can also be used
2. Twist loc abrasive disc 40 grit, 100 grit, 150 grit
3. Sandpaper
• 220 grit
• 320 grit wet/dry
• 400 grit wet/dry
• 600 grit wet/dry
• 1000 grit wet/dry
• 1500 grit wet/dry
4. 6” bench buffer or grinder with a buffing wheel installed
5. White aluminum oxide for general purpose buffing and Red rouge for high polish
6. You will definitely get your hands dirty, you may want to get some mechanics gloves during the sanding and polishing. Also if you are using a bench buffer, you may want to get some thicker gloves as the caliper will heat up a little as it is being buffed and you don’t want to burn your hands or drop the caliper as it heats up.
Now to get to work! If you have an extra set of calipers to work with, you will not need to remove the ones on the car, or you can work with them on the car instead. For this write up, I will give instructions on polishing calipers that are removed from the car already.
Pictured below are the calipers before any work is done to them.
1. First step is to clean the calipers from all grease, dirt and debris before you start your work.
2. At this point you can prep and paint the caliper any color you would like and then start grinding and smoothing. This would be to fill in the grooves on the top of the caliper and to add a little personalization to them.
3. Now that your calipers are cleaned of all debris, you can start grinding / sanding them down. I initially used a mini die grinder with 40 grit sanding disc to clean up the rough finish, grind down the casting line and remove the dimples that are on the front of the caliper.
Pictured below are the calipers after disc sanding and removing the casting line and dimples.
4. Now that you have the casting line removed and the dimples are gone, you can continue using 100 grit sanding disc and then 150 grit sanding disc to start to remove any of the previous grinding marks and begin the smoothing process.
The next process is the most time consuming of the most important to get a nice clean mirror polish
5. Begin by using 220 dry sandpaper to remove the last of the grinding marks
The calipers below are sanded using 220 grit sandpaper to begin removing the grinding marks.
6. Now is when you want to start using the 320 grit wet/dry sandpaper and wet sand the calipers. At this point you will want to start cross sanding by sanding in one direction and then using the next higher grit sandpaper in the opposite direction to smooth out any imperfections
7. After you start in one direction with 320 grit move on to 400 grit, 600 grit, 1000 grit and then 1500 grit
Pictured below are the calipers after wet sanding
8. Now you should be looking at a caliper that is almost shiny, but not polished yet. This is where the bench buffer comes into play. If you do not have a bench buffer, you can use a small buffing wheel on a high speed drill or start to polish with polishing compound by hand.
9. You can use the white polishing compound bar and dress the buffing wheel before you run the caliper on the wheel to begin the shining process.
10. Once you have an initial shine, you can use the red rouge on a new buffing wheel as you do not want to use the same wheel for 2 different compounds.
Below you see the top caliper that has been polished with the red rouge and the bottom caliper has been wet sanded and ready to polish
Here are my stock V6 brakes before I replaced them
Here are the R/T Calipers and drilled/slotted rotors installed
11. Now that this step is done and you have achieved a shine that is satisfactory, you are done and ready to mount your shiny calipers back on your ride.
Here are the polished calipers with the wheel mounted. They really stand out now vs the stock V6 calipers. Plus the braking is greatly improved.
Good luck to all. Any questions, let me know.
fnkycld is offline
Old 11-18-2009, 07:46 AM   #2 (permalink)
Points: 8,303, Level: 1 Points: 8,303, Level: 1 Points: 8,303, Level: 1
Activity: 46% Activity: 46% Activity: 46%
yamabob's Avatar
Car: 2007 chrysler 300c
Member Number: 14746
Excellent write up for those who will attempt this.Thanks for taking the time
AFE, Corsa Catback, Predator,HHP High Flow Cats,JBA Shorties,HHP Stage1 cam,HHP CMR tune,6000k HID low & fogs,AAC 6k halos,Original American Illuminated Rear wing 347 rwhp,375 rwtq,20" chrome SRT rep's,rear SRT trunk spoiler,SRT front lip. Luxer interior LED's, Grip grill,22Elite console cover
yamabob is offline
Old 11-18-2009, 08:19 AM   #3 (permalink)
Points: 4,999, Level: 1 Points: 4,999, Level: 1 Points: 4,999, Level: 1
Activity: 30% Activity: 30% Activity: 30%
NWH_300C's Avatar
Car: 2006 Chrysler 300c Magnesium Pearl
Member Number: 15764
great mod, cheap to do, and really cleans up the area....
NWH_300C is offline
Old 11-18-2009, 08:42 AM   #4 (permalink)
Points: 90,099, Level: 1 Points: 90,099, Level: 1 Points: 90,099, Level: 1
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Trader Rating: (6)
Great writeup fnkycld! I'm going to copy your post into our Tech Tips For Review.
EDIT: Well, I just noticed it's already in that forum...haha. That being the case I'll do something different. I'll copy this thread into another area and leave just your post in the TTR forum.
Bernie
Rambit is online now
Old 11-18-2009, 08:49 AM   #5 (permalink)
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Trader Rating: (6)
There, done - TECH TIP REVIEW: How to polish aluminum brake calipers.
This thread can still be used for comments. Thanks again!!!
Bernie
Old 11-18-2009, 09:28 AM   #6 (permalink)
fnkycld's Avatar
Thanks guys. I figured that I get so much other good information on there that I would offer something up as well.
Now to start polishing the rear calipers.
fnkycld is offline
Old 11-18-2009, 11:42 AM   #7 (permalink)
Points: 8,356, Level: 1 Points: 8,356, Level: 1 Points: 8,356, Level: 1
Activity: 63% Activity: 63% Activity: 63%
CoolVSRT8's Avatar
Member Number: 18060
Trader Rating: (7)
thanks for the write up but me i prefer my silver brembos
2005 Cool Vanilla 300C
CoolVSRT8 is offline
Old 11-19-2009, 08:54 PM   #8 (permalink)
Points: 29,511, Level: 1 Points: 29,511, Level: 1 Points: 29,511, Level: 1
HEMMISSEY's Avatar
Car: 2005 300c VIP Modular Forged Wheels
Member Number: 983
nice write up!!!!
<--12" WIDE--> Club
Slammed and cambered out...
HEMMISSEY is offline
