Go Back   Chrysler 300C & SRT8 Forum > Tech Tips Forum > FAQ Archives
Old 11-22-2004, 09:04 AM   #11 (permalink)
mileshoover's Avatar
Member Number: 85
make your own gas cap holder:
WARNING -- READ THE ENTIRE THREAD TO GET THE CURRENT INFO. DO NOT USE THE VELCRO FIX FIRST DISCUSSED, CONSIDER USING THE MAGNET WITH A LOCKING GAS CAP.
go to
Gas caps & holder
Miles
mileshoover is offline
Old 11-22-2004, 09:13 AM   #12 (permalink)
Member Number: 85
install dash speakers:
go to
Tech: How to Install Dash Speakers
Old 11-22-2004, 09:33 AM   #13 (permalink)
Member Number: 85
use the EVIC for technical information.
Go to
Access EVIC Data & Diagnostic Trouble Codes
Old 11-22-2004, 10:10 AM   #14 (permalink)
Member Number: 85
lower your front license plate holder:
go to
Lowering front license plate holder
Old 11-22-2004, 10:30 AM   #15 (permalink)
Member Number: 85
get your Chrysler Extended Warranty:
go to
Chrysler Extended Warranties
Old 11-22-2004, 11:22 AM   #16 (permalink)
Car: 2005 All option except Nav an factory u-connect 300C
Member Number: 99
Way to go Miles, you're really getting these threads to-gether!!! Good work.
Cdnhemi is offline
Old 11-22-2004, 03:36 PM   #17 (permalink)
Administrator
Northern Rider's Avatar
Member Number: 538
select & install custom dash kits:
Go to this thread...
http://www.300cforums.com/forums/sho...ight=dash+kits
Northern Rider is online now
Old 11-22-2004, 03:40 PM   #18 (permalink)
Administrator
Member Number: 538
set up a stereo aux input:
Go to this thread:
Stereo Aux input - The nitty Gritty.
Old 11-22-2004, 06:19 PM   #19 (permalink)
Member Number: 85
fix rattles in the dash:
go to
http://300cforums.com/forums/showthread.php?t=1877
Old 11-23-2004, 02:46 AM   #20 (permalink)
jamoleh's Avatar
Car: 2006 Chrysler SRT-8
Member Number: 832
Send a message via MSN to jamoleh Send a message via Yahoo to jamoleh
disable the seat belt sound:
From The cars Manual:
"Note:
The following steps must occur within the first 60 seconds of the ignition switch being turned to the ON or START position. DaimlerChrysler does not recommend deactivating the Enhanced Warning System (Belt Alert)."
1.Turn the ignition switch to the LOCK position and buckle the driver's seat belt.
2.Start the engine & wait for the Seat Belt Warning Light to turn off.
3.Within 60 seconds of starting the vehicle, unbuckle & then re-buckle the driver's belt at least three times within 10 seconds, ending with the seat belt buckled.
"Note:
Watch for the Seat Belt Warning Light to turn on while unbuckling and off while re-buckling the seat belt. It may be necessary to retract the seat belt."
4. Turn off the engine. A single chime will sound to signify that you have successfully completed the programming.
The Enhanced Warning System (Belt Alert) can be reactivated by repeating this procedure.
"Note:
Although the Enhanced Warning System (Belt Alert) has been deactivated, the Seat Belt Warning Light will continue to illuminate while the driver's seat belt remains unbuckled."
'08 Jeep SRT-8 ( Steel Blue )
Founder of
HEMI Club U.A.E.
for more info. about the club PM me or Xxo0oxX
jamoleh is offline
