U1418 error code - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 12 (permalink) Old 08-17-2012, 06:15 PM Thread Starter
Points: 2,328, Level: 1 Points: 2,328, Level: 1 Points: 2,328, Level: 1
Car: 2006 Chrysler 300c Hemi
U1418 error code
Hello,
My mate has a 2005 hemi, with 32000 on the clock. Recently he had the ABS ESP/BAS lights come on and cruise control stopped working.
Went through the forum, did the key dance and came up with the U1418 error code. He changed the Right rear abs sensor and did a reset by removing fuse 11.
Quick spin round the block and no difference back with code u1418 and lights on.
Spent hours looking on forum and t'internet and there appears to be no answer for a cure after the "fix" fails.
Is there anything else he can try or do before going to the dealers to get parted from his hard earned!
Mine is a few thousand miles behind his and whatever happens to his happens to mine not long after so if it's an expensive fix mines getting sold. !!!
fujifilm is offline
post #2 of 12 (permalink) Old 08-18-2012, 05:46 PM
Points: 82,226, Level: 1 Points: 82,226, Level: 1 Points: 82,226, Level: 1
MADDOG's Avatar
U1418 - Implausible Right Wheel Distance Signal Received:
1. Set Condition: The PCM gets an implausible signal over the Can C circuit from the ABS module or the FCM (non-ABS). The circuit is continuously monitored.
2. Possible causes:
a. Vehicle speed sensor fault active in ABS module.
b. Can C bus shorted.
c. Can C bus open.
d. Faulty ABS module
e. Faulty PCM
3. Diagnosis & Repair:
a. Test vehicle speed sensor. Failure = replace.
b. Test ABS module. Failure = replace
c. Test/visually check ABS module harness connection and wiring for damage or loose connections.
d. Test/visually check ABS sensor harness connection and wiring for damage, dirt, or loose connection.
e. Check/Clean main PCM harness connection.
f. Test PCM (StarScan)
There's not much here besides checking the wiring and connections you or your bud can do. If you've replaced the right rear wheel ABS sensor, that's a good first step.
Cost at the dealer will be one hour diagnostics time (shop rate) + parts and labor to replace the faulty component. Cost will depend on what needs to be replaced. Hopefully it's an ABS module vs. the PCM!
Michael
MADDOG is online now
post #3 of 12 (permalink) Old 08-18-2012, 07:55 PM
Administrator
Points: 100,665, Level: 1 Points: 100,665, Level: 1 Points: 100,665, Level: 1
Activity: 59% Activity: 59% Activity: 59%
Kaiser Bill's Avatar
Car: 2008 300c SRT-8 {LCC}
Does he have the headlights coming on when the remote unlocking activates?
check the 10A fuse for the steering control module/steering column control module. If it has blown, check to see if you have courtesy headlights on unlocking the car is activated in the EVIC. If you have, disable that feature & replace the fuse, (because thats what seems to blow it)
I had a similar error - anything related to the indicator stalk (high beams, wipers/washers etc, indicators etc), plus cruise control, plus front windows airbags, traction control etc etc stopped working all because of that. The individual fuses for those features remained OK & unblown
Watching You Avoiding Me!
Kaiser Bill is offline
post #4 of 12 (permalink) Old 08-19-2012, 07:24 AM Thread Starter
No luck
Thanks for replys, we checked fuses today no luck, although for some reason the reverse sensors started working again which had also stopped working when abs lights etc came on.
Looks like he's off to dealership for some cash extraction.
fujifilm is offline
post #5 of 12 (permalink) Old 08-19-2012, 08:32 AM
Administrator
more than likely its one of the front TPMS sensors in that case - we've had a rash of weird faults over here caused by them - everything from airbags to imobiliser faults. They cause a short in the canbus
post #6 of 12 (permalink) Old 09-10-2012, 02:58 PM Thread Starter
Update
Quick update for future reference.
My mate took it into merc specialist (avoids Chrysler dealers) had it checked out.
The problem turned out to be exciter ring, new drive shaft because Chrysler do not sell rings seperate!!
fujifilm is offline
post #7 of 12 (permalink) Old 09-10-2012, 08:32 PM
MADDOG's Avatar
It was diagnosed as the ABS reluctor ring? Damn...that's an expensive fix for a piece of geared plastic.
post #8 of 12 (permalink) Old 09-11-2012, 03:13 AM Thread Starter
Update
They advised him to have both sides done!? apparently the faulty ring is warped.
I had one go on a Ford Cougar but they are known for it. Not read of anyone with that problem on Chrysler or the E class for that matter.
fujifilm is offline
post #9 of 12 (permalink) Old 02-28-2013, 05:34 AM
Points: 5,353, Level: 1 Points: 5,353, Level: 1 Points: 5,353, Level: 1
antleeds's Avatar
Car: 2010 Chrysler 300c
Hi
I have the similar ABS lights on
Do you have a reluctor ring on the front non driven wheels?
Thanks guy`s
antleeds is offline
post #10 of 12 (permalink) Old 02-28-2013, 10:01 AM
Points: 3,017, Level: 1 Points: 3,017, Level: 1 Points: 3,017, Level: 1
Montreal300's Avatar
Front has a ring as well but it's part of the hub bearing housing assembly.
Montreal300 is offline
Error code P2015 chads300CRD UK & Europe Regional Forum 36 05-01-2013 03:59 AM
error code P2015 chads300CRD Problems / Dealer Service 3 03-25-2011 06:50 AM
P1593 error code Begemot General Discussion 2 06-09-2010 08:32 PM
Hooray! My first Error Code! -_- Midnite Blu Problems / Dealer Service 0 09-08-2009 09:47 PM
Help with Flashpaq error code. Hawaii Five-O Tuning/CMR/Dyno/DataLogging/Gauges 3 07-14-2006 09:12 PM
