V1 install goes wrong - couldn't ground it or power it - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 11-29-2012, 11:34 PM   #1 (permalink)
Points: 2,566, Level: 1 Points: 2,566, Level: 1 Points: 2,566, Level: 1
Car: 2013 Chrysler 300s v8
Member Number: 41423
I went with what I have done in the past and ripped out the rear of my cigarette compartment to install my v1 power wire.
There are a red, black and yellow with blue stripe wires plugged into it. I tried the red wire first and used my clip to tap into it. I then tried to ground it by putting the black wire into the screw that the console attaches to ashtray. Metal screw to metal clip but attached to plastic. Does not work!
So I get my tester and see that I get a read off the yellow and blue wire. Tap that one and try holding the ground to metal screw...nothing
So I feel that it's my ground wire but I could not find anywhere - anywhere! To ground the dam thing correctly. Does anyone have some guidance here. The stupid fuse box is in the trunk and I can't go that route and I don't like the mirror housing bc I have had a short before bc of that.....
Guidance is appreciated here..
Wizo is offline
Old 12-09-2012, 08:33 PM   #2 (permalink)
I think I was speaking in tongues in that rant about my install issues. I figured out what to do.
1st the red wire is the power wire that plugs into the rear pin of the cigarette lighter. The yellow with blue stripe wire is the illumination wire and works only when the lights are on - hence my issues because I was installing inside my garage and the lights would come on.
Grounding it was simple after I realized it was an issue for circuit. I found a bolt that had the top end of a screw protruding from it and found a nut to sandwich the ground wire. Thing of beauty now.
Buried all my wires and presto.
Word to the wise here...I have seen installs that use mirror or sunroof to find power for their install. Be very careful that you choose the right wire to tap and you don't damage anything up there. I had a damaged sunroof wire that kept an open circuit in my car. Went through 3 batteries and an alternator on my old e55. $2,500 later the tech found the previous owner ripped out his hard wire connection and damaged the wires....wow it sucked big time.
Wizo is offline
Old 12-10-2012, 11:52 AM   #3 (permalink)
Points: 28,869, Level: 1 Points: 28,869, Level: 1 Points: 28,869, Level: 1
MADDOG's Avatar
Member Number: 11602
Glad ya got that all figured out!
Michael
MADDOG is offline
Old 12-10-2012, 02:38 PM   #4 (permalink)
Points: 2,107, Level: 1 Points: 2,107, Level: 1 Points: 2,107, Level: 1
JTSRT8's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 34607
I used the map lights.
Predator 93 CAI tune,LMI Hammer,180 tstat,DC Sports strut bar,
catch can,Ipod interface,hard wired V1,15% tint,Yellow fogs, black grill
JTSRT8 is offline
No power, No heat, the Power Company says power will be restored by the 12th of Feb! Inferno07 Off-Topic Discussion 41 02-11-2010 07:34 PM
Low Beam Install, what am I doing wrong? fireman144 Appearance General Discussion 2 02-15-2007 04:02 PM
The story of my install, when things go wrong CaveMan Car Audio/Alarms/UConnect/Navigation 0 02-07-2007 08:24 PM
How to install the 12-volt power harness of the HK Drive + Play System Professor General Discussion 11 10-01-2006 02:58 PM
Install help! Where is a 12V/ground source??? NIQUE Car Audio/Alarms/UConnect/Navigation 1 06-30-2006 12:30 PM
