Need Help 911 05 300c 5.7 RWD Shaking steering wheel
Ok, my problem is a problem many seem to have in the 300's. My car is an 05 300c RWD, is lowered 2'' and sit's on 20's. The "shake" is only in the steering wheel and the car has no clunks, doesn't pull left or right, no slop, has SOME camber out(lowered and can't take it in anymore), two BRAND new tires, that have been balanced and the car was JUST aligned. I've replaced both inner and outer tie-rod ends and NOTHING has seemed to fix the issue. The tires made it SLIGHTLY better(old tires were bad) and nothing has made it worse. WHAT is the problem with these cars? All the posts on here only said to replace the above parts or perform the alignment and all that. What can I try next? It's SUPER aggravating to have the steering wheel shake @ speeds above 45mph+ It slightly gets better above 75mph and it's at it's worst around 58-68mph. WHAT can I try next? People say to take the 20's off but I don't think that's the problem. They are balanced and not bent or anything.
