Car: RIP 2007 Chrysler 300C SRT8 T-Boned on Sept 3 2011- Welcome 2008 300C SRT8
Member Number: 6743
Are you getting a code? P0420/0430? 420 is the driver's side-430 passenger side. Catalyst efficiency below threshold. Remove the downstream O2 sensor on the side in question, and give it a good scrub with some fine sandpaper. Sometimes deposits on the sensor can trigger the code. It's worth a try to do that, or even replace the downstream O2 sensor, to see if it rectifies the problem, before looking for replacement cats, as they are expensive. You can also try this:
From the 2008 LX service manual:
"The catalyst monitor uses dual oxygen sensors (O2S's) to monitor the efficiency of the converter. The dual O2S's strategy is based on the fact that as a catalyst deteriorates, its oxygen storage capacity and its efficiency are both reduced. By monitoring the oxygen storage capacity of a catalyst, its efficiency can be indirectly calculated. The upstream O2S is used to detect the amount of oxygen in the exhaust gas before the gas enters the catalytic converter. The PCM calculates the A/F mixture from the output of the O2S. A low voltage indicates high oxygen content (lean mixture). A high voltage indicates a low content of oxygen (rich mixture).
When the upstream O2S detects a lean condition, there is an abundance of oxygen in the exhaust gas. A functioning converter would store this oxygen so it can use it for the oxidation of HC and CO. As the converter absorbs the oxygen, there will be a lack of oxygen downstream of the converter. The output of the downstream O2S will indicate limited activity in this condition.
As the converter loses the ability to store oxygen, the condition can be detected from the behavior of the downstream O2S. When the efficiency drops, no chemical reaction takes place. This means the concentration of oxygen will be the same downstream as upstream. The output voltage of the downstream O2S copies the voltage of the upstream sensor. The only difference is a time lag (seen by the PCM) between the switching of the O2S's.
To monitor the system, the number of lean-to-rich switches of upstream and downstream O2S's is counted. The ratio of downstream switches to upstream switches is used to determine whether the catalyst is operating properly. An effective catalyst will have fewer downstream switches than it has upstream switches i.e., a ratio closer to zero. For a totally ineffective catalyst, this ratio will be one-to-one, indicating that no oxidation occurs in the device.
The system must be monitored so that when catalyst efficiency deteriorates and exhaust emissions increase to over the legal limit, the MIL (Check Engine lamp) will be illuminated."
__________________ VYPER883 300C... A Demon In Gentleman's Clothing... 300C SRT 8... The Demon's Boss Dressed to the Nine's...
RIP 2007 300C SRT8...Built On Tue Apr 10 21:00:00 PDT 2007. T-Boned On Sat Sept 3 05:21:00 MDT 2011.
Never Once Did She Let Me Down. You Will Be Missed...
"Ever notice how you come across somebody once in a while you shouldn't have ****** with? That's me." Clint Eastwood as Walt Kowalski in Gran Torino.
The Following User Says Thank You to vyper883 For This Useful Post:
We got the p0430 code. Dealer is replacing the cat under the emissions warranty. I'm guessing they checked the o2 sensors and determined them to be working. Either way we get a new cat, which will help when we move to California! Thanks for the replies guys. Can over filling with oil cause a condition that will deteriorate a cat conv?
Very useful and great video, thanks
__________________ One step for man, one giant leap for mankind
