New battery installed - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 01-07-2013, 11:05 PM   #1 (permalink)
Points: 850, Level: 1 Points: 850, Level: 1 Points: 850, Level: 1
NOTBASIC's Avatar
Car: 2005 Chrysler 300c
Member Number: 32736
just got the Autozone dura last platinum.... It's a AGM battery.... My question is that there's like a exhaust tube that was installed on the oem one and this one doesn't have a place to install one. I went back to them and they stated that I purchased a premium battery that doesn't let off the fumes of a standard battery so I have nothing to worry about...... I called three of their locations and they all said the same. I just wanted to check with u guys to make sure..... Thanks for the advise and I pray they are right
NOTBASIC is offline
Old 01-08-2013, 08:53 AM   #2 (permalink)
Points: 1,066, Level: 1 Points: 1,066, Level: 1 Points: 1,066, Level: 1
Member Number: 40440
You don't need it. I got a yellow top duralast in mine without that tube and works just fine. But when you put that oem battery in another car the battery will die quick with out the tube
Sent from my SCH-I605 using AutoGuide.Com Free App
JFierro2010 is offline
Old 01-08-2013, 08:58 AM   #3 (permalink)
Points: 34,538, Level: 1 Points: 34,538, Level: 1 Points: 34,538, Level: 1
Activity: 19% Activity: 19% Activity: 19%
Member Number: 1483
FYI, this from Ask.com:
AGM stands for absorption glass mat, so named because these batteries are made up of mats in which thin glass fibres are woven to increase the surface area. This allows the AGM battery to work like the flooded lead acid battery with the exception that the electrolyte in the AGM battery does not freely flood the plates but rather is held in the glass mats.
The thin glass fibres do not absorb the electrolyte nor are they affected by the acidic electrolyte but simply hold the electrolyte preventing it from spilling when the battery is tipped over. Although the AGM battery is built in a rectangular case that meets BCI battery codes the plates themselves can be just about any shape including flat, cupped or wound.
Advantages of an AGM Battery
There are several advantages to an AGM battery, which include:
•Unspillable. This means even if these batteries get tipped on the side or turned upside down the electrolyte is not going to spill out of an AGM battery. That makes this battery good for the environment and safer to handle.
•An AGM battery never needs watering. It is considered to be maintenance free. This makes these batteries ideal to use in situations where getting hold of water to water a battery may be an issue.
•AGM batteries don't give off any gas when being charged so there is less worry about having the right ventilation when charging an AGM battery.
•AGM batteries can withstand very low temperatures without freezing or cracking.
•AGM Batteries are highly vibration resistant due to their sandwich construction, making them the ideal battery to use in circumstances where vibration could otherwise be an issue.
Disadvantages of AGM Batteries
While AGM batteries have a lot of advantages that make them the ideal batteries to use in many circumstances, they do have a few disadvantages that should be noted:
•The cost of the AGM battery makes it a less attractive choice than the flooded lead acid battery for most every day uses.
•The deep cell AGM battery can only be discharged to 50% whereas the flooded lead acid deep cell battery can be discharged to 80%, which means that the flooded lead acid battery will run longer on a single charge.
•If an AGM battery is overcharged it will definitely shorten its life and could immediately kill the battery. So extra care must be taken when charging these batteries to ensure they are not overcharged.
Although an AGM battery does have some disadvantages, it is still a great alternative to flooded lead acid batteries in many situations.
DESIREE is offline
The Following User Says Thank You to DESIREE For This Useful Post:
07Srt877777 (02-12-2013)
Old 01-08-2013, 09:10 AM   #4 (permalink)
NOTBASIC's Avatar
Wow thank you!!!! Life saver man!!!! There's nothing like peace of mind
NOTBASIC is offline
Old 02-12-2013, 10:51 AM   #5 (permalink)
Points: 312, Level: 1 Points: 312, Level: 1 Points: 312, Level: 1
Member Number: 40527
Best Battery for double duty
Hello,I own a 2005 300c with 5.7 hemi. I am looking at buying a power inverter to hookup to car in order to provide emergency power 115VAC to sump pump,freezer etc. The dealers of these power inverters state that a Deep Cycle Battery needs to be installed in the car.Any suggestions on best battery to purchase? Thanks alot for your replies!
Rmany is offline
Old 02-12-2013, 01:48 PM   #6 (permalink)
Member Number: 1483
Good luck running a home freezer off your car.
Further good luck finding an inverter that'll handle a home freezer!
DESIREE is offline
Old 02-12-2013, 01:56 PM   #7 (permalink)
NOTBASIC's Avatar
Well I have a 1000 watt amp, HID head/fog lights with ballets, and everything functions good no flickers or shortages. I would hit up a car audio shop that works on RVs and I'm sure they can hook u up with all that u need
Sent from AutoGuide.com App
NOTBASIC is offline
Old 02-13-2013, 06:41 PM   #8 (permalink)
Points: 1,316, Level: 1 Points: 1,316, Level: 1 Points: 1,316, Level: 1
Activity: 43% Activity: 43% Activity: 43%
Member Number: 23718
That's a good find Desiree Thanks !!
Montreal300 is offline
New Battery chrisp European & Diesel Powered 300 Models 21 11-18-2012 05:45 AM
Is my battery about to die? Surreyuk European & Diesel Powered 300 Models 10 09-17-2011 02:25 AM
? RKE Battery Low Lisamel General Discussion 15 04-28-2008 07:16 PM
second battery 300cWannaBe Car Audio/Alarms/UConnect/Navigation 2 10-17-2006 08:04 PM
